valve cover baffle ?
i currently run the trick flow sbf valve covers and their oil fill tube kit. naturally the valve covers aren't baffled so oil is making its way up the fill tube and into the breather which essentially is making a mess. the oil fill tube is just like factory with the vent port on the neck so i have a small breather clamped on. pcv system is stock valve with a 1 way check valve and oil separator. what should i do about this valve cover situation, should i attempt to baffle it with sheetmetal or something or should i just plug the oil fill neck? this is a supercharged car so it needs to vent somehow but this oil mess i cant deal with.
