mustangt562 Member Jan 22, 2004 226 0 16 Long Beach Jun 18, 2007 #1 Jun 18, 2007 #1 My valve cover bolts keep backing out. Which ones you fellas using that stay in them heads? Thanks
BlownFiveLiter have car, will race....wait, it doesn't run 15 Year Member Nov 29, 1999 3,133 18 108 Chicagoland Jun 18, 2007 #2 Jun 18, 2007 #2 That's a new one on me, usually it's header bolts backing out. I suppose you could pick up some lockwashers?
Stanger007 Founding Member Sep 26, 2001 2,015 2 46 Baton Rouge, LA Jun 18, 2007 #3 Jun 18, 2007 #3 I've had good luck using spreader bars. Here's my most recent purchase: http://store.summitracing.com/partdetail.asp?autofilter=1&part=SUM-G3435&N=700+0&autoview=sku Wes
Redsnk95 Founding Member Feb 3, 2002 2,243 1 0 Houston, TX Jun 18, 2007 #4 Jun 18, 2007 #4 ARP valve cover studs.
final5-0 Mustang Master Apr 6, 2003 6,817 12 79 DFW Texas Jun 18, 2007 #5 Jun 18, 2007 #5 Left is a regular or typical lock washer Center is a stainless steel lock washer I use on header bolts Right is what I use on my VC bolts When I moved from oem VC's to Fox VC's my oem bolts were too short because the Fox VC's cast Aluminum is thicker than the oem stamped steel VC's. I got bolts a bit longer in length and I selected cheap bolts as you are not doing anything but just crushing the VC gasket to seal it anyway. I used those above lock washers with the longer bolts and all has been good to go from the time I put the combo together in late 2002. Grady
T trickflow5oh New Member Jun 25, 2006 1 0 0 Jun 18, 2007 #6 Jun 18, 2007 #6 just put a lock washer on the bolt use some red lock tite and torque to spec. you should be good after that, to be safe check it a week later and hopefully problem solved.
mustangt562 Member Jan 22, 2004 226 0 16 Long Beach Jun 18, 2007 #7 Jun 18, 2007 #7 Stanger007 said: I've had good luck using spreader bars. Here's my most recent purchase: http://store.summitracing.com/partdetail.asp?autofilter=1&part=SUM-G3435&N=700+0&autoview=sku Wes Click to expand... how do those work? for some reason I cant picture it in my head. A pic would be great
C Chris_Red_V8 New Member Dec 2, 2004 95 0 0 Scottsdale, Az Jun 18, 2007 #8 Jun 18, 2007 #8 what size are our valve cover bolts?
final5-0 Mustang Master Apr 6, 2003 6,817 12 79 DFW Texas Jun 18, 2007 #9 Jun 18, 2007 #9 Thread Locker should pose no problem for OEM iron heads. I'd take a pass on using it with the softer threads of Aluminum heads myself. Grady
True 5.0 Member Sep 22, 2006 237 0 17 Southeastern Wisconsin Jun 19, 2007 #10 Jun 19, 2007 #10 I've been using these gaskets from Earl's and they work great. http://store.summitracing.com/partdetail.asp?part=EAR-29E03AERL&autoview=sku http://store.summitracing.com/partdetail.asp?autofilter=1∂=EAR%2D29D03AERL&N=700+4294925237+4294908331+4294840126+4294886211+115&autoview=sku
