Valve Cover Clearance...Help!
I got a nice set of Mickey Thompson valve covers to put on a '89 GT w/E7 heads, Cobra Intake w/ 1" phenolic spacer. It seems that the built in baffle where the breather goes slightly hits the rocker arm...My question is can I just cut off the baffle and eliminate my problem or am I better off getting another set of valve covers and putting these on ebay. If figure the stock valve covers don't even have breathers so It should'nt matter. What do you guys think?
Baffles are always a good idea. If you're experiencing clearance problems try to use two VC gaskets for extra height, or try to beat the baffle upwards with a small hammer until you can clear the RRs. Remeber the baffle prevents oil from being sucked into the TB, or for those insisting on using breather caps it shoots oil out of the breather onto the VC and sometimes the header if it's bad enough.
Tim
