  • 1994 - 1995 Specific Tech
Valve cover Help! needed ASAP
  • Thread starter Thread starter Danny's 94Cobra
  • Start date Start date Jul 14, 2005
D
Danny's 94Cobra
68
  • Jul 14, 2005
I have a 94 cobra that I am overhaulin. I installed a pair of Trick Flow Street Heat heads on my car with 6.75 Trick flow push rods and Sorpion 1.72 rockers. My stock valve covers dont appear to clear the rockers they hit on the studs for the rockers. Has anyone installed taller Valve covers without having to space the intake. I know I can buy a spacer for my intake and install tall valve covers, but I have a vortech S-trim on the car and I dont want to have to modify or replace my inlet tube and lengthen my egr pipe to my header. Any help would be greatly appreciated asap I planned to install my engine back this weekend so would like to overnite any parts if possible.
final5-0
Mustang Master
Apr 6, 2003
6,817
12
79
DFW Texas
Jul 14, 2005
  • Jul 14, 2005
LOL, Those Scorpions are BIG aren't they?
I used fox body vc's with mine.
I had to remove a tiny bit of material from a couple of the bosses and the splash guard had to go with my AFR's. I also had to make a little adjustment to the oil fill tube.
Things might be a little different since you run TFS heads.
If you want to go this route you can find lots & lots of threads with the details and some of them even have pics.
Later
Grady
D
Danny's 94Cobra
68
  • Jul 14, 2005
Thanks do you know of any aftermarket vc that may work
Are the fox body valve covers a little taller than ours? I really wanted to install the cobra ribbed valve covers from summit but I don't know if they will clear even if I have to modify the baffles I wouldnt mind it is very little space that I need.
sociopath5.0
155
somewhere near Louisville, KY
Jul 14, 2005
  • Jul 14, 2005
The Cobra VC's you are referring to have an oil fill that will not clear the throttle body, in addition to the baffle plate screw bosses interfering with the rockers. I have the same problem, and I am currently trying to find a solution. Tall VC will not clear the lower portions of the upper intake, even with a 1" spacer. Even if I use a spacer, anything larger than 1/2" will cause the TB to hit the strut tower brace. I have to use a 1/2" spacer because of my Aeromotive fuel rails, a 3/8" won't clear them. FUN TIMES. Good luck and lets keep each other posted about possible solutions.
final5-0
Mustang Master
Apr 6, 2003
6,817
12
79
DFW Texas
Jul 14, 2005
  • Jul 14, 2005
Yes, they are just tall enough to work with the larger rr's but yet I used no spacer of any kind.
I run an Edel RPM so your TFS intake might be a little different.
Later
Grady
D
Danny's 94Cobra
68
  • Jul 14, 2005
cobra intake is what I am using
Sorry for not mentioning it by I am still using my stock cobra intake
final5-0
Mustang Master
Apr 6, 2003
6,817
12
79
DFW Texas
Jul 14, 2005
  • Jul 14, 2005
I mis read your post and somehow got the idea you were using a TFS intake.
The Cobra intake sits a little lower so you most likely will have to be a little creative when it comes to making everything fit.
Later
Grady
D
Danny's 94Cobra
68
  • Jul 14, 2005
Thanks for the input
Thanks for the input. I got my motor back last night and thats when I found the problem. My motor is on my engine stand right now. This Saturday I am going to moch (spelling?) everything up to see what I can figure out. If anybody has any other ideas please let me know. (I which this nightmare would end and I can have my car running again).
a50sn95
368
Elk Grove, CA
Jul 20, 2005
  • Jul 20, 2005
Hmm. I was searching for "valve covers" when I found tis thread. I have TFS Street Heats, TFS 1.7 Rockers, TFS intake and Fox valve covers. The oil fill tube works (had to mod the cap a bit), but I DO have to space the intake 3/8" to clear at the EGR valve (which means I have to lengthen my EGR tube, which has been blocked off for now....). I was hoping to find someone else using this combo and STOCK V/C's......
Oh yeah, GRIND the bottom of the EGR valve where it was hitting the Valve Covers.....
final5-0
Mustang Master
Apr 6, 2003
6,817
12
79
DFW Texas
Jul 20, 2005
#10
  • Jul 20, 2005
  • #10
Our stock tiny tin vc's are very short to clear everything that might get in the way which is a lot of stuff due to the elbow intake air system thing.
I'm pretty sure the only stud mount rr's that will fit under the stock vc's are the Comp steel rr's.
Those Scorpion's are way too big to get em under the tiny stockers.
Later
Grady
K
Engine Gt40p vs 180 procomp
  • Kleinjj27
  • Oct 27, 2026
Fox 5.0 Mustang Tech Nov 3, 2026
Kleinjj27
K
D
Question about EGR valve, replacement, and a part on the valve.
  • DPP
  • May 9, 2026
  • SN95 V6 Mustang Tech
SN95 V6 Mustang Tech May 23, 2026
DPP
D
  • 68_Disgustang
  • Feb 22, 2026
1965 - 1973 Classic Mustangs -General/Talk- Oct 19, 2026
mattcrp1
M
H
Ongoing Battle With Hydraulic Lifters
  • hailer06
  • Jun 8, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jun 9, 2026
Forced Induction Bypass valve backwards?
  • Dontknowchit
  • Jun 25, 2025
Fox 5.0 Mustang Tech Jun 29, 2025
JD1964
