Well this is a new engine that I have been trying to get running right. The only time it runs right is in the mid to upper RPM's. I fixed the first problem I had which was a leaking injector and another with a terrible atomization/spray pattern. The Vacuum of the engine is terrible at idle also (if it can be made to get down to a good idle rpm). I posted awhile ago asking about the low vacuum, but I am thinking this has to be a major part of the problem.
The engine is as follows:
4.020" bore, JE/SRP 8.9:1 pistons, Speed Pro rings: gapped .020" top, .018" bottom (prepped for a s/c) AFR 165 heads, Comp cams XE270HR-14 cam, 1.6 Harland Sharpe rockers, Cobra intake, yada yada...............(anything else needed, just say so).
Vacuum gauge was used with the port on the manifold where i'm assuming the equivalent to the stock, had the Evap system hooked up (first port after TB)? At roughly 800 rpms, I see 11-13" of vacuum, and the valve covers aren't far behind. However, the odd thing is when I get the oil cap off, the manifold vacuum drops another 2" or so of vacuum.
The write-up by Mr. Yount is fairly good, any further ideas to throw my idea with the excessive valve cover vacuum situation?
