Engine Valve Cover Vent Hose Necessary?
dstang01
170
Vancouver, BC
Hey folks, doing a head swap and my new valve covers don't have a fill neck with a nipple for the vent hose. Should I look for a cap with a hose or would I be fine deleting it? Doesn't the PCV take care of venting?
The PCV valve is where it goes out of the crank case, you need a vent for fresh air to come in. It doesn't have to be a hose, you can use a breather cap.
Kurt
Thanks, I picked up something like this from the parts store and it should work!
Does that have a breather element in it, or is it just a baffle? If there is no breather filter inside of it, that nipple has to be connected with a hose back to the intake.
Kurt
You might also want to take metered air into consideration if you don't keep the system closed..........
Really. That's like a big vacuum leak. I wouldn't be surprised if many surging idle issues are caused by adding unmetered air into the equation.
I would tend to agree with you given the size of the hole in the PCV valve, but I've never seen it make a difference.
Kurt
