valve covers dont fit...
riceslayer302
Banned
Oct 3, 2006
CT
i just got my stock style efi ford racing valve covers from summit.
Ford Racing M-6582-A301R - Ford Racing Aluminum Valve Covers - summitracing.com
i tried to fit them on my AFR185's with 1.6 Scorpion rockers, and they are about an 3/8's inch too high, the baffle under the oil spout is knocking and the mounts for a breather hole.
i heard that the taller valve covers wont fit under the intake (RPM II) but i can grind the mounts down and either remove, or try to shorten the baffle... any ideas?
My buddy had to use 5/8 inch think gaskets to clear the rockers with stock height covers, and then had to use a 1 inch intake spacer to get the intake to clear the cover. He ordered some Ford Racing covers and i don't think they had baffles in them...if they did then he cut/ground them out.
Sam - you will run into alot of little things that wont quite fit.
Where are they hitting the rockers - with stock covers - you need to take the oil baffle out and also grind some areas.....shoot me a pic of your new valve covers and I will show you where to grind them - or maybe I can stop by this weekend and show you.
I will be in Lebanon this week - I have to take my new GT to emissions.
