Valve guide/seal help, please
87_stang
131
Tonganoxie, KS
I have an 87 5.0 GT and I tore down the motor last year and put new rings and bearings in it. I also took apart the heads. I had a book (chiltons) and it didn't explain very well how to put in the valve guides and seals and I didn't pay attention to how I took them out. If anyone can help me with this it would be very appreciated. I also need to know how to exactly tighten down my valve springs. Thanks in advance for any help.
Also, I know its my own fault for not paying attention when taking them apart, I had a book so I just figured it would explain everything. Thanks again
Are you saying you took the valve guides out because theyre part of the head casting on stock heads. As for putting the seals on the guides, the way I do it is lube the inside of the guide with white lithium and then put the valve in. Then lube the inside of the stem seal where the valve stem actually moves up and down with white lith and lightly push it onto the valve stem. To get it seated on the guide, its best if you have something round that fits around the valve and is just big enough to cover the seal so you can push it on evenly. It really isnt hard, just take your time and be clean. Then the valve stem guide seals will hold the valves in place for you while you put the springs and keepers back on. If you already have the engine apart I recommend changing the lower intake seals as well if you didnt already. Between that and the valve seals, my car burns less than a half quart between changes.
You removed the guides? This has to have the head heated and the guides pressed out, then new ones installed. Most machine shops will but new guides in for about $100 including the guides.
I have a seal installer but you can also use a deep socket 12mm in many cases, lube the valve as mentioned above to prevent any damage to the seal. As fas as assembling the head, you should check the installed height then go from there. If you need more put shims in, put the spring on, put the retainer on, use a valve spring compressor to compress it, and isntall the locks. Check all pressure, clearances, etc..and your good.
If you have never done this and do not have the tools, take it to a local machine shop. Most will set that all up for less the $100 for a stock style set-up.
