valve spring question
  • Thread starter Thread starter raleighstang65
  • Start date Start date Jul 14, 2007
raleighstang65
170
Wake Forest, NC
Jul 14, 2007
  • Jul 14, 2007
I'm in the process of installing a new camshaft (Performer Plus). I want to put new valve springs in while I'm at it. Do I need to put air pressure on the valves? Don't have an air compressor. Will I screw something up if I just remove the valve springs without air?
D
danny clemens
728
  • Jul 14, 2007
I've never changed valve springs with the heads on the car but I do know that they make a fitting to fit your spark plug hole so you can put air to the cylinder. That won't do you any good unless you have some type of air pressure. If you have an air tank that would probably work or maybe you could borrow a compressor.
You might be able to get the cylinder that you are changing springs on to top dead center and maybe the valve won't drop down too far for you to be able to get the new spring on. This is definately a maybe. Somebody who has tried it before may be able to give you more insight on wether this will work or not.
Putting pressure to the cylinder would be the best way I'm sure.
D
D.Hearne
11,730
south louisiana
Jul 14, 2007
  • Jul 14, 2007
Don't try it with the piston at TDC. Not without something else to hold the valves up. Best thing is to do it with air pressure. You can buy a cheap compressor at Wal-Mart, Lowes, Home Depot, just about anywhere for less than you'll spend renting one. Doesn't take a lot of volume to hold the valves in place. You WILL need the spark plug fitting though. In any case, run the new cam with the old springs till it's good and "broken in" before swapping the new ones on. Your cam will thank you for it..
hhead
280
so cal
Jul 15, 2007
  • Jul 15, 2007
I don't know bout running the springs you have now! What's the lift on the new vs old? The cam card should say what springs to run.
All you need is the old springs not enough pressure and bind....lose keeper....dropped valve.......
raleighstang65
170
Wake Forest, NC
Jul 15, 2007
  • Jul 15, 2007
I guess I need to suck it up and get a compressor. This is my first cam swap so bear with me... With the plug fitting for the air, I'm guessing I would pull one plug and replace the two springs at a time, then plug the next plug, put the air on that one, etc.
It's a Performer Plus cam and Edelbrock Sure Seat Valve Springs that are supposed to match the cam.
D
D.Hearne
11,730
south louisiana
Jul 15, 2007
  • Jul 15, 2007
You got the sequence right. The Performer plus cam isn't a big one, your stock springs will work fine with it for break in purposes. You don't want stiff springs for cam break in.
raleighstang65
170
Wake Forest, NC
Jul 15, 2007
  • Jul 15, 2007
Thanks D.Hearne! Any other tips you can offer?
D
D.Hearne
11,730
south louisiana
Jul 15, 2007
  • Jul 15, 2007
Don't use too much cam lube on the lobes, use none on the lifter's sides, a small amount on the bottoms. Once you have the cam in place and the lifters in the holes, pour all the rest of the oil all over the lifters in the valley. Prime the oiling system before starting the engine. Make sure the engine will fire up quickly (you'll need to get the timing close to right on beforehand) You know how to do this, right? Don't use synthetic oils. Good oil to use for break in is one of the diesel oils or a non detergent straight 30 weight. The trick here is not to get the cam lobes so slick that they don't get a grip on the lifter bottoms at startup. The lifters HAVE to spin to survive. You can run it a few minutes with the valve covers off to verify all the pushrods are spinning. If these are spinning, the lifters are as well. Once you have verified this, just place the covers back on while it's running to limit the mess. Ford Racings' valve cover stud & nut sets are great for this. Screw the studs in place, set the gaskets on the studs and after you've run it, set the covers in place on the studs. Run the engine at 1500-200 rpms for 30 minutes to break in the cam. If everything goes well, kill it and change the oil and filter. If you have a lifter not spining, that lifter and cam lobe are or will be toast in short order. I also liberally coat the distributor gear with Moly grease to help them break in together. Take your time in assembly and don't get in a hurry. If in doubt, ask questions. Good Luck.
raleighstang65
170
Wake Forest, NC
Jul 15, 2007
  • Jul 15, 2007
Thanks again! As soon as I can get the balancer off I think I'm good to go.
Rusty67
20+ Year Stangneter
Dec 3, 2002
3,749
37
109
LA, CA
Jul 15, 2007
#10
  • Jul 15, 2007
  • #10
Use the ballancer puller tool for that.
If you want to change the valve springs without pulling the heads, take all the spark plugs out and get some nylon chord you can feed into the cylinder. Stuff a bunch of it in there and leave some hanging out so you can get it out later (that part is really important). Raise the piston on that cylinder to TCD. The valves now wont fell into the cylinder if you take the valve springs/mount hardware off.
D
D.Hearne
11,730
south louisiana
Jul 15, 2007
#11
  • Jul 15, 2007
  • #11
Only problem with stuffing rope down the hole to keep the valves in place, is wondering if you put enough to do the job. If it ain't enough, you're going to play hell getting the retainers and keepers back in place. There's no doubt in using air pressure.
Rusty67
20+ Year Stangneter
Dec 3, 2002
3,749
37
109
LA, CA
Jul 15, 2007
#12
  • Jul 15, 2007
  • #12
I was suguesting this because he doesn't have an air compressor. If the cylinder wont hold air then the air compressor method wont work. Then again if the cylinder wont hold air then he has bigger problems and provably has to pull the head anyways.
D
D.Hearne
11,730
south louisiana
Jul 15, 2007
#13
  • Jul 15, 2007
  • #13
Right. I just thought I'd let him know the hazzards of using the rope or string method. Get a large enough compressor, anything can be made to hold. You know , like one of those Ingersoll-Rand industrial types on a 4 wheeled buggy ? But what would the neighbors think ?
Rusty67
20+ Year Stangneter
Dec 3, 2002
3,749
37
109
LA, CA
Jul 15, 2007
#14
  • Jul 15, 2007
  • #14
LOL. Ya, knowing the particulars of different methods is good. I wish I had a compressor like that.... I don't think the HOA would like me very much =-)
Mach 1 iac valve in a 4.6 gt
  • solodriverz
  • Jun 3, 2026
  • SN95 4.6L Mustang Tech
SN95 4.6L Mustang Tech Jun 5, 2026
squeak93
D
Question about EGR valve, replacement, and a part on the valve.
  • DPP
  • May 9, 2026
  • SN95 V6 Mustang Tech
SN95 V6 Mustang Tech May 23, 2026
DPP
D
Engine (EGR Deleted) Solution the hotter combustion chambers?
  • PonyGTrider
  • Jan 21, 2026
  • 3 4 5
4K
Fox 5.0 Mustang Tech May 2, 2026
PonyGTrider
H
Ongoing Battle With Hydraulic Lifters
  • hailer06
  • Jun 8, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jun 9, 2026
Brakes FOX BRAKES ISSUES
  • PonyGTrider
  • Jan 11, 2026
  • 2 3
2K
Fox 5.0 Mustang Tech Jan 31, 2026
Mustang5L5
