Valve spring question
  • Thread starter Thread starter 3uzfte
  • Start date Start date Apr 3, 2010
3uzfte
  • Apr 3, 2010
Hello all, I have exhausted my searching, and have found most of my answers however I have a few that remain unanswered. My story goes like this, I have a stock 5.0 block, stock everything. It is now in a 64' Falcon where I decided to pull GT40 intake u/l, heads, and injectors from a 96 Explorer. I had the heads milled .030, and got the correct push rods, I just don't want a spring to stay up as P-to-V clearance will be tighter, so spring pressure is of some concern to me. I am running a stock HO cam, and I want to upgrade to roller rockers eventually, but I just don't have the money now.
My problem is... I have read that the stock explorer valve train will not hold up to the stock HO cam, but then I read that the same spring is used in the E7 heads as the GT40 heads. Obviously I want stiffer springs, however the heads are back from the shop after a fresh valve job sporting new hardware. With all that in mind, can I run the stock GT40/E7 springs with the stock HO cam, I'm not drag racing, money is of concern and this is what I have. I have obviously read about the Trick Flow kit from summit for like $120, but is it really worth it? I have read horror stories, but then others say no problems. To my understanding crane sells a kit as well. Can I buy just the springs or do the springs require special retainers as the heads were fitted with new hardware this week and I would hate to pay for something twice, especially if they have the same 50/50 result as the Trick Flow springs.
Sorry for the long explanation/questions, I just want to get my entire story out.
Vinnietbird
584
  • Apr 3, 2010
Use the after market springs.Way better and the stock Explorer springs are really too soft even for a stock H.O cam.
3uzfte
  • Apr 3, 2010
Thanks for the reply, I'm going to go ahead and order them today.
Engine Hiccup at full throttle
  • keel
  • Jun 2, 2026
Fox 5.0 Mustang Tech Jul 30, 2026
keel
9
Engine Donor '00 Mountaineer meet '91 Fox
  • 91firecracker
  • May 11, 2026
  • 2 3
Fox 5.0 Mustang Tech May 28, 2026
91firecracker
9
D
Engine HO cam in non HO roller block ‘93 f150
  • DanC1993f150
  • Mar 21, 2026
Fox 5.0 Mustang Tech Mar 29, 2026
General karthief
Fox Valve Spring Kit PAC-1219X. Help finding needed additional parts.
  • 93gtmustang
  • Jul 29, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jul 31, 2026
93gtmustang
T
Oil burning on my recently buil 302
  • The blk67
  • May 15, 2026
Fox 5.0 Mustang Tech May 15, 2026
