valve train geometry?
  • Thread starter Thread starter hotrodt
  • Start date Start date Jul 12, 2008
hotrodt
60
  • Jul 12, 2008
1988 5.0 this block originally had a hydraulic flat tappet cam in it. I bought a new set of lifters for it and a comp cams 305h camshaft, after putting the cam in i dropped the new lifters in and they sit down in the lifter bores 1/4" at full lift the lifters are out of the lifter bore a maximum of 1/16" something just isn't working here. Any help would be appreciated.
347HO
462
Seattle
Jul 12, 2008
  • Jul 12, 2008
An original 88' HO 5.0 is not hydraulic flat tappet.
The reason your lifters are sitting low in the bore... the bores are taller to accomodate the hydraulic roller lifters.
Just for ****s and giggles... does your lifter valley have two small threaded holes, one forward and one aft in the valley? If yes... those were to bolt down the spider assembly for the original roller lifters.
hotrodt
60
  • Jul 13, 2008
I had to tap and thread those holes myself the raised part was there but they were not tapped. This motor came out of club wagon van. I don't know what i need to do next.
hotrodt
60
  • Jul 13, 2008
This motor did not have roller lifters in it when i took it apart that's what i don't understand
347HO
462
Seattle
Jul 13, 2008
  • Jul 13, 2008
My bad.
That is a 302ci which is not an H.O. so that's why you didn't have rollers in there to begin with.
The lifter bores are designed to accept the roller lifters.
In all honesty, I suggest you return that camshaft and lifters and buy a roller camshaft and some Ford roller lifters.
By design, the "roller" setup will outperform the HFT setup.
You may also run almost any oil with a "roller" setup too.
hotrodt
60
  • Jul 13, 2008
roller cam it is. Now to solve the other problem in the other thread. Thanks bud
H
Ongoing Battle With Hydraulic Lifters
  • hailer06
  • Jun 8, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jun 9, 2026
Forced Induction Prepping for supercharger on non-stock build
  • 91fox427
  • Nov 25, 2025
Fox 5.0 Mustang Tech Jan 5, 2026
Qtrhrse23
N
Looking for ECU/CHIP for 1992 5.0
  • Nathan26
  • Sep 26, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Oct 8, 2026
Qtrhrse23
  • 68_Disgustang
  • Feb 22, 2026
1965 - 1973 Classic Mustangs -General/Talk- Oct 19, 2026
mattcrp1
M
My next project , a 428 build!
  • horse sence
  • Jul 29, 2026
  • 9 10 11
5K
Classic Mustang Specific Tech Wednesday at 6:44 PM
DadLife0724
