  • 2.3L (N/A & Turbo) Tech
vam
  • Thread starter Thread starter svolx2003
  • Start date Start date Mar 16, 2004
svolx2003
41
  • Mar 16, 2004
I need info. on "Big" Vams,"you should have the "big" VAM. (What someone else told me,diffrent site)for my 86' 2.3T???
Thanks for all the info. that you guys been givin me latley!!!!
Stinger
7,754
24
118
Basehor (Kansas City), KS
Mar 16, 2004
  • Mar 16, 2004
It's the vam found on SVO's, 87-88 TC's, etc. They have a 3" inlet/outlet instead of the standard 2.5" "small" vam. You need a big vam computer to use it though (unless you are running a Merkur computer).
Stinger
P
Pro-Hawk
971
West Texas
Mar 16, 2004
  • Mar 16, 2004
My car has got VAM issues out the butt lol I would almost use a 2.5" VAM if it worked
Stinger
7,754
24
118
Mar 16, 2004
  • Mar 16, 2004
Well if you'd put it back under the hood it would probably function a little better
P
Pro-Hawk
971
West Texas
Mar 17, 2004
  • Mar 17, 2004
That may help
I got a set of VAM's and each one does different deals. One of them allows me to drive the car but I detonate around 10psi of boost. I'm thinking its running lean. The next VAM is a reman one, with it on the car want idle at all, it gets to around 500 RPM and dies. Someone said to check for a vaccum leak but I just got through driveing the car with no problems into the garage to swap VAMs again?
kiddiccarus
The first widely accepted Tranny
20+ Year Stangneter
Dec 24, 2003
1,789
1,051
143
30 Mins from a Ragged GT
Mar 17, 2004
  • Mar 17, 2004
measurements on the VAM are interior to interior or outer to outer? and both sides are the same size right?
Stinger
7,754
24
118
Mar 17, 2004
  • Mar 17, 2004
That is the outside of the inlet/outlet
kiddiccarus
20+ Year Stangneter
Dec 24, 2003
1,789
1,051
143
Mar 17, 2004
  • Mar 17, 2004
OK now IM confused.......I just went out to the garage and measured the VAM. Well I was under the impression that the small is 2.5 outer to outer, and large is 3 outer to outer. I used 3 different tape measures to get the measurement because I was unsure and each time it was 2 3/4 so I took the part numbers off of it and am hoping that one of these two can match somebodys out there. E5ZF-12B529-AA and
0280 202 71
Stinger
7,754
24
118
Mar 17, 2004
  • Mar 17, 2004
E5 means it was made in 1985...don't know more than that. I've honestly never seen anybody have trouble with it.
kiddiccarus
20+ Year Stangneter
Dec 24, 2003
1,789
1,051
143
Mar 18, 2004
#10
  • Mar 18, 2004
  • #10
well that does make it a little simpler thanks
F
5 lug disc brake pad help
  • Foxrider714
  • Nov 14, 2025
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Nov 17, 2025
KRUISR
C
2003 Mustang GT - Rear Tire Size Question
  • Cassiebaebae
  • Jun 29, 2026
1996 - 2004 SN95 Mustang -General/Talk- Jul 6, 2026
Cassiebaebae
C
I
2023 mustang gt fastback help
  • Izhar8709
  • Mar 22, 2026
  • The Welcome Wagon
The Welcome Wagon Mar 23, 2026
LILCBRA
P
New here
  • PortCity
  • Jun 9, 2026
  • The Welcome Wagon
The Welcome Wagon Jun 9, 2026
AeroCoupe
D
Early ford 302 heads
  • Dagasser
  • May 4, 2026
  • The Welcome Wagon
The Welcome Wagon May 4, 2026
