When you reinstall the RR (pedestal mount) what do you torque them down to, or do you tighten them until you cant tighten them anymore?
If the lower intake gaskets look ok can they be reused( i know i am being cheap) and what do you torque the lower to 2o lbs final?
Also is there a way to check the injectors when they are not in the car to see if they work good. Is there a good way to clean them with them out of the car.
Does anyone know of anykind of way to hook up the radiator hoses with the -an line or type hose, or any thing other than the regular rubber.
Also why do most people use distilled water in the radiator for the cooling system rather than just tap water, is it better to use city water or just well water if you don't use distilled.
sorry for a bunch of stupid questions, but some stuff i have just been wondering about for a while. Good time as any to ask i guess
thanks
Jason
thanks
Jason
