Versailles Rear End Assembly
nemlio65
87
Other than the oil seal that's in the axle tube and the axle flange gasket.What other seals are required?I've read there's supposed to be a both inner and outer oil seals.In the shop manual it looks like only one inner seal.
There are two seals per side --inner and outer.
Parts numbers from O'reilly's:
1975-1980 GRANADA/MONARCH/1977-1980 VERSAILLES 9-INCH REAR END (Disc Brakes) (Large Axle Bearing Housing)
1. Axle Bearings: p/n 88128 RA (2 req.)
2. Axle Seals: (Inner) p/n 51098, (Outer) p/n 3794 (2 req.)
3. Axle Bearing Retainer gaskets: p/n 55036 (2 req.)
4. 3rd Member-To-Housing Gasket: p/n RDS-55074
5. Pinion Seal: p/n 7044NA
http://www.ultrastang.com/Rearinfo.asp?Page_ID=16
I got a set of tapered roller bearings when I changed to a set of Moser 31 spline axles. If you get this type of bearing, there's only 1 seal on the bearing itself and then the gasket for the flange. Simple and no pressing it the inner/outer seals required!
Got the axle shafts in over the weekend.According to the shop manual the torque spec for the end cap bolts is 90 to 120ftlbs.These are the 1/2 inch bolts that attach the caliper mounting braket to the axle flange.does that torque spec seem right for that application?:nono:
End cap bolts are those bolts that hold the spool in place if I'm not mistaken.
