Vert Showbar
they say that they will fit 87-93's but they are really made for 90-93's where the speaker grill is exposed and you can run the bolts into the body through the speaker hole. on the ones with the carpeted rear trim (like mine) you have to make cuts in the top of the rear 1/4 trim so that it can be slid back around the pipe that runs through the bar.
ill post a pic of the cut im talking about later.
Always said if I had a vert, I'd get one of these. I like the ones with the high third brake light.
Someone had a module that would switch your brake lights from the light bar to the trunk depending on if top was down or not...real slick.
Damn, I wish I had a vert....or t-tops.
ya know, i love my vert but i hardly ever put the top down, only if its not real hot, the sun will flat BAKE you in the summer. spring and fall, FTW!
I need to get the heater core fixed so i can use it more as it cools down in the fall.
