VERY aggrevating suspension/HELP
why does my car ride so frickin rough. I replace with eibach pro kit and koni adustibles and i feel every crack in the road. could something else be wrong? Maybe better springs....I want to get new rims but with no give in my suspension i think they'll bend. help
A rough ride is the result of a lowering spring - thats just how it works. You could either find a set of FMS B-springs, which IMO, look much better than Eibachs and will probably help your ride a little bit, or put stock springs back on the car. Mustangs aren't a car made for someone who has ride quality in mind. I would not buy different rims, especially if your going to get a larger size wheel with low profile tires. They will only make the ride worse. You could try replacing the bushings in the suspension to see if that would help with the ride.
Joe
Joe
Exactly right.
