I just got done installing my new TFS twisted Wedge heads and the car is running like crap. The headers are smoking, it has a hesitation, it runs rough. I don't know what to do. Help me please.
TrueBlue95GT said:Ok I used those gaskets that you told me about and they worked like a charm. Car sounds meaner than it ever has before. However, it's still not running right. Now, the idle starts surging up and down starting small at first and then getting bigger and then it finally dies. I'm going to try redoing the valvetrain. Do you think it would be better to go 1/2 turn more after zero lash?
TrueBlue95GT said:I'm going to try redoing the valvetrain. Do you think it would be better to go 1/2 turn more after zero lash?
final5-0 said:How about a brief expaination of your adjustment method.
Stud or ped rockers?
Later
Grady
TrueBlue95GT said:Since I don't have the car registered or insured yet, I can't really bring it out on the road for tuning much. I set the stud mount roller rockers in this way: Start on number 1 cylinder and turn the motor until I notice that the valve is all the way closed. The pushrod was as far down as it would go and then I would wait a minute or 2 til the lifter settled and then I would tighten the fulcrum nut until I could feel the pushrod contacting the rocker arm. Then I turned the nut another 3/4 turn. Then I tightened the hex center. I used this for all the rocker arms. There's no valvetrain noise. I'm wondering if they're too tight also. What's weird is that at idle the vacuum is around 18inhg at idle and then when I keep it revved to like 3000rpms, the vacuum is around 22inhg, which the car has never pulled in before. I've got a lot more vacuum than I've had before, so I'm guessing these heads are working how they are supposed to. I read many places that 3/4 turn after zero lash is the way to go but alot of places said 1/2 turn and 1/4 turn for drag strip only. What do you all recommend?
