- Jul 14, 2004
- 45
- 0
- 0
Ok at the end of last year I bought this car(see bottom for specs please) and posted the problem. well I took some trouble shoot advice and we are still scratching our heads. Here is the deal the car will run for about 20-30 minutes and shut off. The car will not restart for about an hour and usually dies even quicker maybe 15 minutes.The check engine light is always on reason I'm thinking is the mass air meter is stock and the car has 24 lbs injectors so it is running very rich.
Here is what we have tried, we changed out the TFI module didn't work. We have changed the coil didn't work. The guy I bought the car from said he removed the MSD ignition box didn't work. You can hear the fuel pump turning on so we are not sure if it could be that.One thing we tried was spraying some starting fluid in the intake.It did turn over.So that got us confused on if it is spark or fuel we thought for sure it was spark but now we are not sure.So here is what we are going to try. Hooking up a fuel pressure gauge, putting in a different computer removing the msd box ourselves. After that we will really be scratching our heads again. I'd appreciate any input thanks
-Steve
Car sepcs:
1990 mustang
New ford racing 5.0 short block
eldlebrock performer heads
eldlebrock intake
MSD ignition box distrubtor coil
holly 255 in take fuel pump
24lbs injectors
Stock massair on the car but need to get my pro-m massair meter recalibrated
BBK headers into a basanni Xpipe in to mac mufflers
Car was switched from automatic to T5.
Almost everthing on the car is brand new less then 3k miles
let me know if i left out any information
-Steve
Car sepcs:
1990 mustang
eldlebrock intake
24lbs injectors
