very wierd engine behavior
  • Thread starter Thread starter tommy_1812
  • Start date Start date Jan 22, 2006
T
tommy_1812
41
Kerrville, TX
Jan 22, 2006
  • Jan 22, 2006
A few days ago, I was driving my car around a lot. A lot of turning off the car, turning on the car and so forth. Around the afternoon, the car started acting funny. I would have to start it 4 or 5 times to get the engine on. Each crank, the engine would turn over, then instantly die. Giving it gas each time didn't really help until the 4th time or so.
I let it sit for an hour, then started it again. It started but the RPMS idled at 2300, instead of 700. After letting it idle for 5 minutes there was smoke coming from the spark plug area on the left side of the engine. I pulled out the dipstick and the oil was smoking.
After pulling out each wire and placing back in, cleaning off the ignition coil prong, and starting the car back up, it's all normal again. It starts up fine, and drives normally. Was this a bad day for the car? Perhaps driving it too much?
jrichker
StangNet's favorite TOOL
Mar 10, 2000
27,512
2,813
234
Dublin GA
Jan 22, 2006
  • Jan 22, 2006
Dump the codes and see what the computer says is wrong…
Here's the link to dump the computer codes with only a jumper wire or paper clip and the check engine light, or test light or voltmeter. I’ve used it for years, and it works great.
See http://www.troublecodes.net/Ford/
OR
See http://www.mustangworks.com/articles/electronics/eec-iv_codes.html
IF your car is an 86-88 stang, you'll have to use the test lamp or voltmeter method. There is no functional check engine light on the 86-88's except possibly the Cali Mass Air cars.
For those who are intimidated by all the wires & connections, see http://www.actron.com/product_detail.php?pid=16153 for what a typical hand scanner looks like. Normal retail price is about $30 or so at AutoZone or Walmart.
Or for a nicer scanner see http://www.midwayautosupply.com/detailedproductdescription.asp?3829 – It has a 3 digit LCD display so that you don’t have to count flashes or beeps.. Cost is $35.
carbed87
215
  • Jan 22, 2006
jricker is teh mootang master!
bgjohnson
963
johnston,iowa
Jan 22, 2006
  • Jan 22, 2006
For some reason or another you may have loaded up the cylinders and it was trying to get that out while chugging and choking. Or maybe bad gas.
J
Engine Stalling
  • josh40tay
  • Oct 20, 2026
JD1964
Engine Another no start after washing engine bay
  • bruno
  • Apr 26, 2026
Fox 5.0 Mustang Tech May 7, 2026
AeroCoupe
K
Resolved Need some assistance. Holley Terminator X alongside H/C/I. Very rough/inconsistent idle
  • karhoot
  • Jun 6, 2026
Fox 5.0 Mustang Tech Jun 6, 2026
karhoot
K
Engine Random hanging idle
  • 706 Saleen
  • Feb 11, 2026
Fox 5.0 Mustang Tech Feb 19, 2026
86HO5.0
F
Fox 1990 Mustang GT 5.0 A9L – Engine suddenly shuts off but immediately restarts when key turned
  • FishermansFriend
  • Aug 9, 2026
General karthief
