VHT Spray Dye ?
  • Thread starter Thread starter steede302
  • Start date Start date Aug 2, 2007
steede302
75
jacksonville fl
Aug 2, 2007
  • Aug 2, 2007
Im sure someone here has used this on their interior. How did it work and has it held up well over time?
Fett
766
  • Aug 2, 2007
It's similar to SEM vinyl dye, and I swear by it.
Most of the stuff you will paint will not require much prep, I commonly use brake cleaner to clean the material, let it dry, then apply my coats. That works great on the hard plastic stuff like the dash and center console. The softer plastics like the door arm rests (not the pads) and the rear 1/4 trim peices require some prep work. Those typically need the vinyl primer.
My dash and center console look OEM black, I can clean it with black magic and it shines like new. Holds up well, doesn't chip or fade.
Boss 351
Here sthhhhhhhheeeve take a picthh of my man flowe
Jul 13, 2003
2,433
23
48
Canada
Aug 3, 2007
  • Aug 3, 2007
SEM, VHT, Duplicolor
I used Duplicolor and it turned out great. You just really need to prep everything. I took the parts off, cleaned them with soap and water using a brush (you need to get every little bit of dirt out of the cracks)... I also used Acetone (this stuff will melt the plastic if you're not careful).
Fox Full set of seats in the back of a hatch
  • keel
  • Aug 28, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Aug 31, 2026
keel
J
Low RPM jerking
  • Justinkins
  • Jul 8, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jul 11, 2026
fasterthangas
F
N
Power door lock motor Question
  • NYFox
  • Mar 15, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Mar 17, 2026
NYFox
N
347 with Vortech V2 and Holley quick fuel, AFR Renegades a tremec tko 600 advice for newbie pls
  • Schargedfox
  • Jul 20, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Aug 3, 2026
Schargedfox
2003 Mustang GT - Rear Tire Size Question
  • Cassiebaebae
  • Jun 29, 2026
  • 2 3 4
2K
squeak93
