Vib
  • Thread starter Thread starter 65er
  • Start date Start date Mar 3, 2026
65er
12
New Jersey
Mar 3, 2026
  • Mar 3, 2026
Hey All, 65er here again! Was hoping someone could shed some lite on this Vibration issue with my 65 base model. It feels like the tires are out of Balance between 30 + 40mph. smooths out to 50 then starts again, Motor has been replaced and is New, Trans and driveshaft have been rebuilt and has new Tires! To my mind, the only thing left to consider is Wheels and Axles! Any thoughts would be helpful! Thanks.
nickyb
I gotta say i never painted my nuts, Never Ever
3,026
1,658
163
nevada
Mar 3, 2026
  • Mar 3, 2026
Go back to when she didn't have that vibration, what was done right before you noticed it?.
Reactions: DadLife0724
65er
12
New Jersey
Mar 14, 2026
  • Mar 14, 2026
It had that vibration when I bought it, Gonna change the wheels and see how that works.Thanks.
Mcmahst
5 Year Member
Jan 19, 2021
698
277
83
Laguna Woods CA, fort Mohave AZ
Mar 14, 2026
  • Mar 14, 2026
I would take it somewhere and have each of the tires checked for balance and also to make sure there’s not a defective tire. While they check for balance, they can also verify that you don’t have a bent rim. If all that passes, the next thing I would check would be front wheel bearings for run out. I’m sure others will chime in as well.
65er
12
New Jersey
Mar 14, 2026
  • Mar 14, 2026
Thanks, I'll do just as you suggest!
N
Vibration after new clutch
  • nipple_looker
  • Sep 20, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Sep 26, 2026
fasterthangas
F
L
95 gt engine vibration
  • lenzgt
  • May 11, 2026
  • 1994 - 1995 Specific Tech
1994 - 1995 Specific Tech May 26, 2026
lenzgt
L
J
2004 Mustang 3.8L V6 vibrations above 65 MPH and differential leaks
  • joeybuddy96
  • Mar 16, 2026
  • SN95 V6 Mustang Tech
SN95 V6 Mustang Tech Aug 29, 2026
joeybuddy96
J
Drivetrain 8.8 Pinion and 302 rear main seal leaks after replacing. 93 5.0 with t-5
  • Steigy4827
  • Jun 23, 2025
Fox 5.0 Mustang Tech Apr 1, 2026
Steigy4827
Car shakes when taking off help???
  • STANKYstangs
  • May 10, 2026
1996 - 2004 SN95 Mustang -General/Talk- May 27, 2026
LILCBRA
