Vibration @ 4000rpm
  • Thread starter Thread starter BYRDPE
  • Start date Start date May 13, 2004
BYRDPE
1,556
Memphis,Tn.
May 13, 2004
  • May 13, 2004
Hello folks,
Every since I did my AOD to T-5 swap I have been having vibration at around 4000rpm.
I only does it when in gear.It's not really vibrating through the shifter but it's like you can feel it throughout the whole car.
Any ideas??
Thanks for the replies.
88stangmangt
2,332
Stafford,VA
May 13, 2004
  • May 13, 2004
tires might need to be balanced if the whole car is vibrateing.
TT91
1,536
Paramus, NJ
May 13, 2004
  • May 13, 2004
he said it only does it when its in gear...hmm
V
v8only
2,378
22
49
May 13, 2004
  • May 13, 2004
vibrations are almost always caused by the driveshaft. Did you use that aod driveshaft with that stupid balancer on it???
Try unbolting the driveshaft and rotating it over a notch and see if that changes the nature of your vibration. I'll put my money on the driveshaft.
BYRDPE
1,556
Memphis,Tn.
May 13, 2004
  • May 13, 2004
Aluminum DS...I'll try rotating it.
G
gt90stang
568
  • May 13, 2004
This should help you out:
http://home.hiwaay.net/~ctfrench/procedure.htm
Good Luck, Don
BYRDPE
1,556
Memphis,Tn.
May 14, 2004
  • May 14, 2004
Good Luck, Don
Great article...thanks for sharing.
N
Vibration after new clutch
  • nipple_looker
  • Sep 20, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Sep 26, 2026
fasterthangas
F
L
95 gt engine vibration
  • lenzgt
  • May 11, 2026
  • 1994 - 1995 Specific Tech
1994 - 1995 Specific Tech May 26, 2026
lenzgt
L
T5 5th gear 89 gt
  • mac_55
  • Mar 19, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Mar 20, 2026
Mustang5L5
Drivetrain 8.8 Pinion and 302 rear main seal leaks after replacing. 93 5.0 with t-5
  • Steigy4827
  • Jun 23, 2025
Fox 5.0 Mustang Tech Apr 1, 2026
Steigy4827
J
2004 Mustang 3.8L V6 vibrations above 65 MPH and differential leaks
  • joeybuddy96
  • Mar 16, 2026
  • SN95 V6 Mustang Tech
SN95 V6 Mustang Tech Aug 29, 2026
joeybuddy96
J
