  • 1994 - 1995 Specific Tech
vibration and pull?
  • Thread starter Thread starter sidewayzstang
  • Start date Start date Oct 12, 2010
sidewayzstang
14
  • Oct 12, 2010
My 94 GT has developed a slight vibration at highway speed and is pulling to the right a little under hard braking. Are these two issues related? what should I check for?
Venom351R
4,548
41
98
MAINE
Oct 12, 2010
  • Oct 12, 2010
The vibration could be the U joints. Does it do it at a specific RPM or speed. Other vibrations can be tire related.
revhead347
Apparently my ex-husband made that mistake.
20+ Year Stangneter
Jun 14, 2004
9,303
1,648
214
Acworth, GA
Oct 12, 2010
  • Oct 12, 2010
Sounds like a brake problem. The front wheel bearings are notorious for developing a wobble. I've had several cars come in, and I was amazed how much the front wheel bearings moved when I checked them with a dial indicator. I'd take your front brakes apart and see what you find.
Kurt
MFE92
1,094
373
124
Phoenix
Oct 17, 2010
  • Oct 17, 2010
94 and 95's were notorious for soft A-arm bushings. They allow too much toe-out at speed, leading to a shimmy. And if your passenger side is worse than the drivers side it might be causing the pull when the brakes are applied.
L
95 gt engine vibration
  • lenzgt
  • May 11, 2026
1994 - 1995 Specific Tech May 26, 2026
lenzgt
L
T
Vibrating clutch pedal
  • t.hite10
  • Aug 10, 2026
1996 - 2004 SN95 Mustang -General/Talk- Aug 11, 2026
squeak93
Acceleration Vibration
  • Blown02svt
  • Dec 31, 2025
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jan 5, 2026
General karthief
H
Strange steering/brake issue
  • Haxmaster
  • Jun 2, 2026
  • SN95 4.6L Mustang Tech
SN95 4.6L Mustang Tech Jun 3, 2026
squeak93
Electrical No dash lights
  • slojoexxx
  • Dec 11, 2025
1994 - 1995 Specific Tech Dec 11, 2025
slojoexxx
