  • 1994 - 1995 Specific Tech
Vibration at and above 80
  • Thread starter Thread starter pirotec354
  • Start date Start date Apr 5, 2009
pirotec354
127
Grand Rapids, Michigan
Apr 5, 2009
  • Apr 5, 2009
Ok so Ive had a vibration coming from the rearend I believe ever since i bought my 94 cobra about a year ago. I never really thought much about it since i dont really drive over 80 too much except for at the track. Once i reach 80 the vibration starts and it souds like its coming from the rear somewhere. Its not a consistant vibration either its more like a wha wha wha type sound. I checked the gears in the rearend and they look perfect still. It has 3.73's in it and a posi locker. Someone told me that it may be because my gears are really tight in the rearend? But if anybody had any idea what this could be or any advice i would appreciate it. Thanks
-Justin
Bramcavender
Active User
Apr 1, 2009
55
Barboursville, WV
Apr 6, 2009
  • Apr 6, 2009
I had a similar vibration about 75mph and I replaced my u-joints and had my rear tires rebalanced and it went away. My friends car had the same issue and his went away after switching to an aluminum driveshaft. hope this helps
ProKiller
3,064
15
78
PA
Apr 6, 2009
  • Apr 6, 2009
have your wheels balanced again. you can have the driveshaft balanced too. i had/have this problem, i've done the tires and it helped, but isn't gone. i'm going to get the driveshaft balanced sometime sooner rather than later hopefully.
Dino Dino Bambino
1,672
89
79
Cyprus
Apr 6, 2009
  • Apr 6, 2009
pirotec354 said:
Ok so Ive had a vibration coming from the rearend I believe ever since i bought my 94 Cobra about a year ago. I never really thought much about it since i dont really drive over 80 too much except for at the track. Once i reach 80 the vibration starts and it souds like its coming from the rear somewhere. Its not a consistant vibration either its more like a wha wha wha type sound. I checked the gears in the rearend and they look perfect still. It has 3.73's in it and a posi locker. Someone told me that it may be because my gears are really tight in the rearend? But if anybody had any idea what this could be or any advice i would appreciate it. Thanks
-Justin
He's a simple test for you to do Justin. Find an empty road where you can relatively safely take you car over 80 and when the vibes begin, depress the clutch pedal so that the tranny is effectively in neutral. If the vibes continue, your problem is most likely to be the rear wheels/tires out of balance (make sure you have equal pressure in both rear tires). If the vibes immediately stop, the problem's drivetrain-related (worn driveshaft u-joints is commonest cause).
pirotec354
127
Apr 8, 2009
  • Apr 8, 2009
Alright cool, ill check that out when i get it back on the road. Thanks guys
L
95 gt engine vibration
  • lenzgt
  • May 11, 2026
1994 - 1995 Specific Tech May 26, 2026
lenzgt
L
J
2004 Mustang 3.8L V6 vibrations above 65 MPH and differential leaks
  • joeybuddy96
  • Mar 16, 2026
  • SN95 V6 Mustang Tech
SN95 V6 Mustang Tech Aug 29, 2026
joeybuddy96
J
Drivetrain 8.8 Pinion and 302 rear main seal leaks after replacing. 93 5.0 with t-5
  • Steigy4827
  • Jun 23, 2025
Fox 5.0 Mustang Tech Apr 1, 2026
Steigy4827
J
Severe shaking/vibrations in steering wheel
  • jacket999
  • May 20, 2025
SN95 V6 Mustang Tech Jun 1, 2025
NtheGAME
N
Fox Fuel Pump Issues After Replacement/Upgrade
  • Ryu
  • Jun 23, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Sep 13, 2026
Ryu
