Vibration At Low Speed/neutral
67rcks
373
I made several changes to the suspension and since the completion a vibration is felt at steering wheel, especially when being in 1-3rd gear, or neutral - the wheel visibly shakes (in 4th gear stops shaking)
The changes were: new lower control arms (moog k3601), low profile pirelli 225/45/17 tires, monte carlo bar, new strut rod bushing, new transmission rubber mount. The car has v8 302 and t5, manual steering.
Have and of you experience this and where did you find the source of vibrations? Wheels should be correctly aligned (done the wheel alighment twice, in-between experimenting with caster and toe). all ball joints are tight.
The wheel actually wavered from side to side, even dashpad was shaking a little.
It turned out that new PU transmission mount, was causing all this! It was stiffer and wider than OE ford rubber mount. It is beyond my imagination how could change in transmission mount have such big impact on the steering.
Check your motor mounts, they may be thrashed and the trans mount is now taking all the vibration and since it is basically a solid mount it is transmitting all the vibration into the chassis.
