Vibration help please...
  • Thread starter Thread starter 89stangalang
  • Start date Start date Nov 21, 2005
89stangalang
58
  • Nov 21, 2005
I have recently started to get vibration in my drivetrain. It has gotten to the point that I can see my shifter even vibrating....scary.... Is this likely a driveshaft or U-joint problem? Or is it the transmission itself? It basically vibrates under load (acceleration) or when cruising at say higher speed in 5th gear. I am sure someone else has experienced this problem and could give me some tips as to how to attack this problem.
srothfuss
Last night I stabbed the same guy 7 times in a row
Oct 17, 2004
1,796
Woodward Ave.
Nov 21, 2005
  • Nov 21, 2005
Is your harmonic balancer stock? In your sig you list a S/C. The stock piece is notorious for failing on a modded car. This could be your problem.
The U-joints don't typically fail (or at least I have not heard of a failure yet.) However, it doesn't hurt to inspect them.
Also, the steel driveshaft can develop a warp if the car is modified. The only way to check this is with a straight edge (long enough) to pick up any curvature in the part.
FORCED2DV8
458
Grand Rapids MI
Nov 21, 2005
  • Nov 21, 2005
Check your U joints, slide under your car and push up and pull down directly on the U joint, if you feel any movement then replace them. If thats not it then the harmonic balancer, I am sure there is a thread in here about that with pics, then check motor mounts trans mounts, Is it running on all 8 cyclinders,,, let us know whata you find....:SNSign:
G
Gears & Crosses
150
Southern, Miss.
Nov 21, 2005
  • Nov 21, 2005
89stangalang,
Have you made any changes to your driveline or have you unbolted the driveshaft for any reason? Check and make sure your driveshaft bolts didn't loosen up on you.
Gears
2000xp8
SN Certified Technician
Aug 8, 2003
8,075
1,658
194
NJ
Nov 21, 2005
  • Nov 21, 2005
Gears & Crosses said:
89stangalang,
Gears
That is very good advice, i've had that happen.
If that's not the case, i would suggest getting a FMS aluminum driveshaft. IMO a stock driveshaft is not worth U joints, unless money is very tight.
89stangalang
58
  • Nov 21, 2005
The supercharger is currently on the car, but not hooked up with the belt. The engine really seems fine to me. I will try and check the driveshaft checked out soon and report back my findings.
N
Vibration after new clutch
  • nipple_looker
  • Sep 20, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Sep 26, 2026
fasterthangas
F
T
Drivetrain TREMEC TKX 1–2 Grinding Issue at ~4,000 Miles + Poor Warranty/Customer Service Experience
  • Ttopfoxguy
  • Oct 10, 2026
Fox 5.0 Mustang Tech Oct 15, 2026
JMG9350
J
Car shakes when taking off help???
  • STANKYstangs
  • May 10, 2026
1996 - 2004 SN95 Mustang -General/Talk- May 27, 2026
LILCBRA
M
Engine Unexplainable Exhaust Pop and Gurgle
  • Mrnissen122
  • Feb 14, 2026
Fox 5.0 Mustang Tech Feb 18, 2026
Engine Stalls when downshifting/coasting
  • Scott_S
  • Nov 5, 2025
Fox 5.0 Mustang Tech Nov 6, 2025
Mustang5L5
