  • SN95 4.6L Mustang Tech
Vibration problem
  • Thread starter Thread starter LaserSVT
  • Start date Start date Mar 20, 2008
LaserSVT
3,548
233
Mar 20, 2008
  • Mar 20, 2008
So im getting this annoying vibration through the whole car after 115 mph. It dosent shake the steering wheel and I can tell its eaither the drive shaft or the rear end. The rear does not make any noise at all normally but at that speed I cant tell. So before I throw parts at it has anyone ever gotten a high speed vibration from gears before? Or is it more than likely the drive shaft and I should just man up and get a FRPP aluminum one?
Smokeurhonda
457
Maryland
Mar 20, 2008
  • Mar 20, 2008
I have the same problem. It's only in 5th gear correct? When I'm hitting 115-120 in 5th it feels like the car is going to shake apart. Then once you hit about 130-135 it goes away and is smooth. I do believe it is a drive shaft related issue because of gears. From the information I've seen, FRPP alum drive shaft should correct your problem.
myponyrocks
I have more billet on the Stang than most women ha
Apr 18, 2004
1,219
Mar 20, 2008
  • Mar 20, 2008
check the U joints, mine did this as well but at 85-ish... was a bolt backing out.
COramprat
...I can take it. I think.
20+ Year Stangneter
Mar 2, 2003
8,474
1,463
223
Sea of Tranquility
Mar 20, 2008
  • Mar 20, 2008
Wow...you must have a long track where you live.
Does the shifter vibrate or is it more like the whole car?
Smokeurhonda
457
Maryland
Mar 21, 2008
  • Mar 21, 2008
My vibration is through the whole car. I top out 4th around 115-120 and then hit 5th and it feels like the car is coming apart.
40th GT
916
Lawrenceville, GA
Mar 21, 2008
  • Mar 21, 2008
Anyone know the torque specs for the u-joint bolts?
Smokeurhonda
457
Maryland
Mar 21, 2008
  • Mar 21, 2008
Yeah, impact gun.
SaleenGT2001
Well-Known Member
Jul 18, 2005
2,811
Four Oaks NC
Mar 21, 2008
  • Mar 21, 2008
my car did the same thing but it was around 130-145 mph. with the new T56 and driveshaft it did not vibrate at all up to 157
this was at the 2 mile track by my house BTW
281CI96Coupe
233
  • Mar 23, 2008
mine was at 85ish as well. Im going to tell my good friend to tighten up the U-Joints as well.
fobra559
At least it's more erect and not floppy anymore.
Nov 1, 2007
721
Lindsay, CA
Mar 24, 2008
#10
  • Mar 24, 2008
  • #10
If your going to get a new DS, I recommend the FMS DS from Summit
N
Vibration after new clutch
  • nipple_looker
  • Sep 20, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Sep 26, 2026
fasterthangas
F
H
Strange steering/brake issue
  • Haxmaster
  • Jun 2, 2026
SN95 4.6L Mustang Tech Jun 3, 2026
squeak93
L
95 gt engine vibration
  • lenzgt
  • May 11, 2026
  • 1994 - 1995 Specific Tech
1994 - 1995 Specific Tech May 26, 2026
lenzgt
L
J
Bad Vibration
  • jefffletch47
  • Feb 12, 2026
1996 - 2004 SN95 Mustang -General/Talk- Jun 2, 2026
dgrinnan
D
Car shakes when taking off help???
  • STANKYstangs
  • May 10, 2026
1996 - 2004 SN95 Mustang -General/Talk- May 27, 2026
LILCBRA
