  • SN95 4.6L Mustang Tech
Vibration while driving??
  • Thread starter Thread starter Wikkdgt
  • Start date Start date Jun 24, 2004
Wikkdgt
445
Cincinnati, OH
Jun 24, 2004
  • Jun 24, 2004
I just had my new wheels put on and I used the tires from my old rims. Anyways when I hit about right at 50mph I get this bad vibration in my steering wheel. This happened on my old rims too when they were mounted. Does anyone know what might be causing this? Do you think it is a bad tire or something with the suspensioin? I think I remember the vibration eventually going away when the old wheels were doing it. Thanks in advance.
awwyea
170
Central MA
Jun 24, 2004
  • Jun 24, 2004
Did you get an alignment done when you put the new wheels on? If the car was out of alignment to start with the new wheels won't help.
Another possiblity is that the tires are cupped from an improper alignment.
Wikkdgt
445
Cincinnati, OH
Jun 24, 2004
  • Jun 24, 2004
No, I never got an alignment since my car was lowered and I don't have my camber kit installed yet.
Cobra Jay
889
Motor City
Jun 24, 2004
  • Jun 24, 2004
Could be the belts are shot in the old tires. Could be cupped too.
mpcv2000
2,371
Montreal , Quebec !
Jun 24, 2004
  • Jun 24, 2004
Looks like a bad tire !
I don't think the front wheels and tires are not balanced right cause they were on the old rims and they were doing it so my guess will be a bad tire...
If they were mounted on the old rim with a bad balanced set up they will have worn bad and by switching them even if they are balanced right the tire itself has a spot(s) on it so there is nothing to do then swapping the front wheels to the rear and give it a try , if the vibration is gone on the steering but now you can feel it on the seat itself it will be comming from the rear .
Time for new tires !
Marine One
276
North Topsail Beach, NC
Jun 24, 2004
  • Jun 24, 2004
You could try rotating the tires from front to back one at a time to try to determine which tire is bad.
Cobra Jay
889
Motor City
Jun 24, 2004
  • Jun 24, 2004
Good idea. Semper Fi!
Marine One
276
Jun 24, 2004
  • Jun 24, 2004
And Semper Fi to you!
twogts4us
4,188
12
79
Dunedin, FL
Jun 24, 2004
  • Jun 24, 2004
Were the tire/wheel combos balanced when they were mounted? Oh, wait, you said you had this problem before. Sounds like your tires have taken a crap. I'd also recommend getting it aligned since you've dropped it.
sixstringthing
297
#10
  • Jun 24, 2004
  • #10
My car does the same thing (it has an eibach pro kit). I recently put 4 new tires on it and it's still doing it.... I don't know what it could be but it's kind of annoying.
mpcv2000
2,371
Montreal , Quebec !
Jun 24, 2004
#11
  • Jun 24, 2004
  • #11
In your case it can be a bent rim(s) , do the same thing , rotate the wheels and see if the vibration comes from a different place is yes and you're sure that the wheels are well balanced , it can be a bent rim ( s ) springs will not do that .
H
Hrspwrd
15
Michigan
Jun 25, 2004
#12
  • Jun 25, 2004
  • #12
Also check your wheel weights, I had one come off on mine and it shook like hell when I'd hit 60mph. If the vibration stops when you let off the gas pedal, it could be a U-joint.
sixstringthing
297
#13
  • Jun 25, 2004
  • #13
I'll check out the rims. I could be on the freeway, let it off the gas and coast in neutral and the vibration is still there, so i guess I can eliminate the U-Joints.
Wikkdgt
445
Cincinnati, OH
Jun 25, 2004
#14
  • Jun 25, 2004
  • #14
I don't want to get new tires because they are only like 6 months old. You think I could take it somewhere and have them figure out which one is messed up?
N
Vibration after new clutch
  • nipple_looker
  • Sep 20, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Sep 26, 2026
fasterthangas
F
L
95 gt engine vibration
  • lenzgt
  • May 11, 2026
  • 1994 - 1995 Specific Tech
1994 - 1995 Specific Tech May 26, 2026
lenzgt
L
Can makes noises when driving poping
  • Creomod
  • Oct 14, 2025
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Oct 19, 2025
Creomod
J
Bad Vibration
  • jefffletch47
  • Feb 12, 2026
1996 - 2004 SN95 Mustang -General/Talk- Jun 2, 2026
dgrinnan
D
Acceleration Vibration
  • Blown02svt
  • Dec 31, 2025
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jan 5, 2026
General karthief
