Vibration With Engine Rpm
dirtboy33
hey guys in new to this forum and also new to the mustang world. I bought a 91 hatch 5.0 with a t5 trans a few weeks ago and love it. but it has a vibration that changes with engine speed. doesn't matter if im sitting in my driveway to driving down the road. starts getting bad around 3000. its at its worst around 3500. then starts to smoothe out around 4000. but there is always a very slight vibration. at first I thought it was the dampner. I could see it wabbling a little. changed that with no help. then I removed the engine belt and ran it. didn't help any. so now I got it in my garage and I pulled the trans out hoping to find something wrong in the clutch/flywheel area. but don't see andthing wrong. the dow pins are there for the clutch and everthing looks good. so I removed the bell housing from the trans and put back on and installed the starter. started the engine with just the clutch and flywheel on the back and the vibration is completely gone. so my question is could a internal problem of the trans cause my vibration even with no vehicle speed or could it be something more simple like a trans mount or cross member bushings? I have been googling this issue for the last couple days and cant find anyone with my same issue. any help would be greatly appreciated.
Check the harmonic balancer on the front of the crankshaft. The outer hub may be lose, wobbly or shifted from its normal position. The outer hub is bonded to the inner hub by a rubber ring. Sometimes the rubber ring tears up and allow the outer hub to move. This causes engine vibrations because the balance weights have shifted with the outer hub.
Could be something in the TRANS. I had the same issue last summer . Pulled TRANS and it stopped . Installed new TRANS and it was still here . Turned out number 4 main bearing was spinning in the bore
Reactions: A5literMan
That's my guess. Big clue is the fact you can see the balancer moving. I am assuming the crank is walking due to a bad bearing. Not that this is a sign necassarily but what's the oil pressure doing?
I hope its not a engine issue haha. The balancer doesn't move anymore now that I have a new one installed. And I havnt hooked a Manuel oil pressure guage up to it yet. But the guage on the dash is above half way all the time even hot.
Get a pressure gauge on it . My stock gauge looked great even with the spun bearing lol .
I'm gonna put a guage on it tomorrow morning before work. And I'm considering pulling the cover off the trans and taking a look around before I put it back in. Also gonna try a new trans mount and crossmember because my mount and bushings are looking pretty old
