Vibration
  • Thread starter Thread starter Repostyle
  • Start date Start date Dec 10, 2005
Repostyle
538
Portland, OR
Dec 10, 2005
  • Dec 10, 2005
Alright all you gear heads,
I can't seem to figure out what is causing a vibration in my car. Here's the scenario: I'm driving along picking up speed as it goes though all the gears in my AOD, 1st = fine, 2nd = fine, 3 = fine, 4th = vibration. I can do the same speed in 3rd without a vibration, or I can do the same RPM in 1,2,3rd without any problems, but once it goes into OD I get a noticeable vibration in the car like something is out of balance. I started noticing this about 3 weeks ago on my way home from work so I thought it might be a rough spot in the road. It's not the road, it will do it anywhere.
I just put new shocks and struts in when I put my lowering kit in, so does that either rule them out or put them as primary suspects for being defective?
Any ideas? I'm pretty sure the trans was rebuilt recently, but I'm not possitive since it was a repo and I don't know it's history. I've taken it to the tire shop and they're balanced so I'm out of ideas.
M
Mike92GT
583
Florida
Dec 10, 2005
  • Dec 10, 2005
Sounds like you may be having whats known as a "washboard shift" It's a real common problem with the AOD, and Ford has had several TSB's for it over the years. It is most often caused by old or burnt trans fluid, and a lot of times just changing the fluid will help. Adding another trans cooler helps sometimes too. Not sure, but I think the vibration occurs when the torque converter clutch engages, which is only when the trans is in OD.
Repostyle
538
Portland, OR
Dec 11, 2005
  • Dec 11, 2005
I will give that a shot, any other ideas while I'm at it?
M
Mike92GT
583
Florida
Dec 11, 2005
  • Dec 11, 2005
Been awhile since I worked on a Fox with an AOD, if it has the small access hole in the bell of the trans, go ahead and drain the torque converter too. Just turn the engine by hand until you see the drain plug in the converter. That way you get almost all of the old fluid out.
willys1
1,004
New Jersey
Dec 11, 2005
  • Dec 11, 2005
are your u-joints good? I noticed you have gears,do you still have the stock drive shaft?
N
Vibration after new clutch
  • nipple_looker
  • Sep 20, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Sep 26, 2026
fasterthangas
F
L
95 gt engine vibration
  • lenzgt
  • May 11, 2026
  • 1994 - 1995 Specific Tech
1994 - 1995 Specific Tech May 26, 2026
lenzgt
L
Acceleration Vibration
  • Blown02svt
  • Dec 31, 2025
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jan 5, 2026
General karthief
P
Fuel New Eldebrock 1406 problems 1985 GT 5.0
  • Paddyman
  • Oct 22, 2026
Fox 5.0 Mustang Tech Nov 2, 2026
manicmechanic007
T
Drivetrain TREMEC TKX 1–2 Grinding Issue at ~4,000 Miles + Poor Warranty/Customer Service Experience
  • Ttopfoxguy
  • Oct 10, 2026
Fox 5.0 Mustang Tech Oct 15, 2026
JMG9350
J
