  • SN95 4.6L Mustang Tech
vibration??.....
  • Thread starter Thread starter four.six
  • Start date Start date Jun 24, 2006
F
four.six
443
Corpus Christi, TX
Jun 24, 2006
  • Jun 24, 2006
ok, i just installed my new TKO... all over the instructions, it mentions how vibration is bad. i did not use a dial indicator durring install... if i have vibration, will it be significatly noticable?? cause when i hold my shifter knob, it does vibrate a tad bit. but, i think my 3650 did the same thing . i guess what im asking is, if it does vibrate in a bad way, will the whole car vibrate or just slightly vibrate in the shifter?? im scared to drive it...
laxdman20
95
Va.
Jun 24, 2006
  • Jun 24, 2006
It will vibrate a little. You will know for sure when you have a BAD vibration.
F
four.six
443
Corpus Christi, TX
Jun 25, 2006
  • Jun 25, 2006
im starting to think this tranny is more hassel than its worth. i took it to 80 mph today and i couldnt even see out of my rear view mirror cause it was vibrating so bad that it made it blurry.. what do i do now??
sjrtx
151
Houston-NW side
Jun 25, 2006
  • Jun 25, 2006
unbolt the driveshaft, turn it 180 degrees, and bolt it up again.
edit: is the driveshaft the correct length?
F
four.six
443
Corpus Christi, TX
Jun 25, 2006
  • Jun 25, 2006
well, the FRPP tech guy told me i wouldnt need a spacer or anything. but the yoke does not go in the new TKO as far as it went in the stock 3650. but the yoke is in the TKO at least 3 inches, so i think that is sufficient. i will try that 180 degree thing.. thanks
stangGT97
1,299
Boston area, MA
Jun 25, 2006
  • Jun 25, 2006
the driveshaft may be out of balance, so as stated try rotating it. But if your car is vibrating at idle, there may be something else at work here. Out of curiosity, is the trans filled to spec with the correct fluid?
L
95 gt engine vibration
  • lenzgt
  • May 11, 2026
  • 1994 - 1995 Specific Tech
1994 - 1995 Specific Tech May 26, 2026
lenzgt
L
Drivetrain 8.8 Pinion and 302 rear main seal leaks after replacing. 93 5.0 with t-5
  • Steigy4827
  • Jun 23, 2025
Fox 5.0 Mustang Tech Apr 1, 2026
Steigy4827
J
Severe shaking/vibrations in steering wheel
  • jacket999
  • May 20, 2025
  • SN95 V6 Mustang Tech
SN95 V6 Mustang Tech Jun 1, 2025
NtheGAME
N
Car shakes when taking off help???
  • STANKYstangs
  • May 10, 2026
1996 - 2004 SN95 Mustang -General/Talk- May 27, 2026
LILCBRA
N
Vibration issue
  • Nicolaj
  • Apr 14, 2024
2K
Classic Mustang Specific Tech Nov 8, 2024
AeroCoupe
