  • SN95 4.6L Mustang Tech
Vibration?
  • Thread starter Thread starter scupking
  • Start date Start date Nov 29, 2007
First Prev 2 of 2
scupking
1,186
Enfield, CT
Dec 1, 2007
#21
  • Dec 1, 2007
  • #21
Ok so this is the DS that I'm going to get. http://www.latemodelrestoration.com/iwwida.pvx?;item?item_no=M4602J 1&comp=LRS
Also I will get this U-joint. How many u-Joints do I need?
http://www.latemodelrestoration.com/iwwida.pvx?;item?item_no=LW-23016 1&comp=LRS
fobra559
At least it's more erect and not floppy anymore.
Nov 1, 2007
721
Lindsay, CA
Dec 1, 2007
#22
  • Dec 1, 2007
  • #22
scupking said:
Is this the one to get?
http://store.summitracing.com/partd...400070+4294907673+4294840044+115&autoview=sku
Yeah, that's the one I got and you only need that and nothing else to do the install. Unless you race a lot a safety loop wouldn't be bad either.
fobra559
Nov 1, 2007
721
Lindsay, CA
Dec 1, 2007
#23
  • Dec 1, 2007
  • #23
lvmustanggt said:
I have question, when you get DS for summitracing do you just take stock out and bolt aluminum ds ? Is that it or have to mod some stuff ? I am thinking to get one for my 02 mustang gt. Is the install easy or take it to shop to make sure proper alignment ?
No, it should bolt right on. Since you have a 5 speed it will bolt right in, but for auto's you would have to swap yokes. You should be fine. It's not that hard to install if your savy but if your not sure have a shop do it. It should only cost $50 bucks or so for the labor. Good Luck
fobra559
Nov 1, 2007
721
Lindsay, CA
Dec 1, 2007
#24
  • Dec 1, 2007
  • #24
Sounds good, It's the FRPP but really it's the same as the FMS one. Why do you need the U joints for? You should be fine with only the DS.
scupking
1,186
Enfield, CT
Dec 1, 2007
#25
  • Dec 1, 2007
  • #25
COramprat said:
The u-joints might be wiped out. They are relatively inexpensive to replace.
Never mind looks like the DS comes with new u-joints. Didn't see that at first.
fobra559
Nov 1, 2007
721
Lindsay, CA
Dec 1, 2007
#26
  • Dec 1, 2007
  • #26
Good Luck man It should be a nice addition to your gears.
First Prev 2 of 2
N
Vibration after new clutch
  • nipple_looker
  • Sep 20, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Sep 26, 2026
fasterthangas
F
L
95 gt engine vibration
  • lenzgt
  • May 11, 2026
  • 1994 - 1995 Specific Tech
1994 - 1995 Specific Tech May 26, 2026
lenzgt
L
Acceleration Vibration
  • Blown02svt
  • Dec 31, 2025
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jan 5, 2026
General karthief
Resolved 2015 ecoboost pp bumpsteer issue
  • matthewt
  • Aug 1, 2026
  • 2015 - 2023 Specific Tech
2015 - 2023 Specific Tech Aug 3, 2026
fasterthangas
F
Distributor installed wrong
  • djj62478
  • Jun 14, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jun 21, 2026
CAMTWO1070
