  • 1994 - 1995 Specific Tech
vibration
  • Thread starter Thread starter chief44
  • Start date Start date Mar 24, 2008
C
chief44
50
Western PA
Mar 24, 2008
  • Mar 24, 2008
I have a vibration. Its all engine. The whole car shakes at idle. I thought it was a plug or plug wire, replaced both plus new cap and rotor, no help. If i rev the engine up it seems like the car wants to move with the clutch depressed. Not sure if it is part of it. Car has 252,000 miles on it. Never had a problem like this. Any ideas? Doesn't matter if car is moving or not.
earleys94gt
1,223
Ashley, Ohio
Mar 24, 2008
  • Mar 24, 2008
Balancer maybe.
See if the seal is 'seperating' around it.
Zero_chance
1,244
Maricopa, AZ
Mar 24, 2008
  • Mar 24, 2008
+1 for the balancer.
94-302-vert
1,947
NE CT
Mar 24, 2008
  • Mar 24, 2008
+2 for the balancer.
saleener94
153
Compton,CA
Mar 24, 2008
  • Mar 24, 2008
If it sounds like something is about to pop, maybe you shouldn't drive it just shut it off and check balancer. Thats what mine did. scared the crap out of me when it did that.
Bosko5.0
1,067
longwood, FL
Mar 24, 2008
  • Mar 24, 2008
+3+4+5 for the balancer. Also check vaccum it should be around 20hg vac steady if it moves up and down there is a leak, My balancer was going , at idle it vibrated like crazy but hold the rpm at 1,000 no vibration.
earleys94gt
1,223
Ashley, Ohio
Mar 24, 2008
  • Mar 24, 2008
Mine was the exact opposite. Idled fine, but at 1,000 rpm it vibrated. Weird...
Bosko5.0
1,067
longwood, FL
Mar 24, 2008
  • Mar 24, 2008
It all depends where the rubber seperates.
mustanglvr95
32
marysville, WA
Mar 25, 2008
  • Mar 25, 2008
wonder if it could be shot motor mounts
hollywoodstang
1,095
Mar 25, 2008
#10
  • Mar 25, 2008
  • #10
might be a balancer and/or universal joint and trans/motor mount. i had the same problem. changed all of them but still have little vibe. might be trans related. throw out bearing flywheel... check all of them and replace if needed. since you have high miles it is good idea to freshen up everything.
C
chief44
50
Western PA
Mar 25, 2008
#11
  • Mar 25, 2008
  • #11
It happened all the sudden, I drove it to work, after work, started it up and it had vibration. Drove it home(40 miles) next morning it seems worse. I parked it. It was a bad day. I ran over a rubber cargo strap that stuck in my rear tire. One hook in the tire, the other dented my door, rear quarter panel. almost a hole!
L
95 gt engine vibration
  • lenzgt
  • May 11, 2026
1994 - 1995 Specific Tech May 26, 2026
lenzgt
L
N
Vibration after new clutch
  • nipple_looker
  • Sep 20, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Sep 26, 2026
fasterthangas
F
T
Vibrating clutch pedal
  • t.hite10
  • Aug 10, 2026
1996 - 2004 SN95 Mustang -General/Talk- Aug 11, 2026
squeak93
Car shakes when taking off help???
  • STANKYstangs
  • May 10, 2026
1996 - 2004 SN95 Mustang -General/Talk- May 27, 2026
LILCBRA
T5 5th gear 89 gt
  • mac_55
  • Mar 19, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Mar 20, 2026
Mustang5L5
