  • 1994 - 1995 Specific Tech
Vibration
  • Thread starter Thread starter hollywoodstang
  • Start date Start date Apr 3, 2008
hollywoodstang
1,095
Apr 3, 2008
  • Apr 3, 2008
I had vibration problems for about 4 months now and i went throught everything including harmonic balancer, wheels, tires, engine mounts and transmission mounts etc etc. i almost gave up finally someone told me to turn the driveshaft 180' and reinstall, so i did it and now my vibration is gone??? how does this make sense???
My car always vibrated around 70 mph, 3500 rpm. now it doesn't weird...
any input on why this makes sense???
I checked the u-joints when i had the driveshaft out and they had no play. i have a aluminum driveshaft by the way.
Thanks
HISSIN50
34
129
Apr 3, 2008
  • Apr 3, 2008
You should not have had an issue with the alum DS. Was it new when you bought it?
In any case, glad to hear you got it figured out.
hollywoodstang
1,095
Apr 4, 2008
  • Apr 4, 2008
No. it was on my old car and i transfered over to the new car. but it had very very low miles on it. I and ford tech inspected the u-joint and it was almost new. It's weird how rotating the driveshaft 180' gets rid of the vibration??? what is the science in this??? Anyways it worked...
HISSIN50
34
129
Apr 4, 2008
  • Apr 4, 2008
The driveline is loosely balanced at the factory, which is why there's a yellow index mark on the DS and a mark/notch in the companion flange. But with your alum DS, it must have been a freak thing where the tolerances all stacked up in one direction and was enough to cause a notable imbalance.
L
95 gt engine vibration
  • lenzgt
  • May 11, 2026
1994 - 1995 Specific Tech May 26, 2026
lenzgt
L
N
Vibration after new clutch
  • nipple_looker
  • Sep 20, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Sep 26, 2026
fasterthangas
F
J
2004 Mustang 3.8L V6 vibrations above 65 MPH and differential leaks
  • joeybuddy96
  • Mar 16, 2026
  • SN95 V6 Mustang Tech
SN95 V6 Mustang Tech Aug 29, 2026
joeybuddy96
J
Drivetrain 8.8 Pinion and 302 rear main seal leaks after replacing. 93 5.0 with t-5
  • Steigy4827
  • Jun 23, 2025
Fox 5.0 Mustang Tech Apr 1, 2026
Steigy4827
T
Drivetrain TREMEC TKX 1–2 Grinding Issue at ~4,000 Miles + Poor Warranty/Customer Service Experience
  • Ttopfoxguy
  • Oct 10, 2026
Fox 5.0 Mustang Tech Oct 15, 2026
JMG9350
J
