Video of my GT at the track
  • Thread starter Thread starter superslothguy
  • Start date Start date May 14, 2011
1 of 2 Next Last
superslothguy
103
  • May 14, 2011
YouTube - 78 trans am w/ nitrous 403
this was a test and tune day for me car kept falling on its face in 1st and second but the launch felt great
car ran 7.55@91 MPH with a 1.61 60FT
Winters98GT
Whoop...whoop-whoop-whoop-whoop...GANGNAM STYLE!!!
1,291
224
H Town
May 14, 2011
  • May 14, 2011
Nice run!
d98gt
4,505
59
204
SE Texas
May 14, 2011
  • May 14, 2011
Pulled the wheel quite a bit. Looks like the car is twisting up a bit though, what suspension mods do you have?
tank_567
731
26
29
Raleigh, Nc
May 14, 2011
  • May 14, 2011
what gears are you running?
slayerripkdc
1,341
brewster ny
May 14, 2011
  • May 14, 2011
Nice launch! What are your mods?
superslothguy
103
  • May 14, 2011
3:73 gears with a 28 inch slick
kenne bell 1.7 (12 psi)
75 mm accufab T/B
JLT ram air CAI
kenne bell boost a pump
focus fuel pump
lighting maf
60 lb injectors
off road H with magnaflow mufflers
and alot more
suspension is stock MACH 1 sping and shocks out back with lakewood 90/10s upfront with a upr coil over kit 150 lb spring tubular k member and A arms also
slayerripkdc
1,341
brewster ny
May 14, 2011
  • May 14, 2011
I sure hope you have subframe connectors! If not...ouch!
superslothguy
103
  • May 14, 2011
lol there on my list of things to buy lol
slayerripkdc
1,341
brewster ny
May 14, 2011
  • May 14, 2011
Im sure you have some pretty bad chassis flex going on there. These cars come stock with chassis flex lol.
superslothguy
103
#10
  • May 14, 2011
  • #10
hahaha i havent noticed it yet thank god need to get em in asap
04GTMustang
348
Stafford
May 15, 2011
#11
  • May 15, 2011
  • #11
question for ya...is 91 what you normally trap in the 1/8th with those mods? I just slapped on a set of 28in mickeys and my trap is right at the 90 ball park on 11psi. I have pretty much the same mods you do minus the suspension work.
Just curious lol. I trapped 95 before the tall tire and i thought there was something jacked up with the car cause i was barely touching 90.
superslothguy
103
#12
  • May 16, 2011
  • #12
idk to be honest i used to trap the same mph with the 9 psi pulley (91)
like i said in the first post this was a test and tune day going back this week to see what it will do now that its tuned im looking for 95-97 MPH
04GTMustang
348
Stafford
May 17, 2011
#13
  • May 17, 2011
  • #13
Ok sounds good man! I am just curious what you make cause im not tuned on 11psi either right now. got a dyno tune on 9psi but the guy backed so much timing off cause he was afraid to blow it cause it made 12.1lbs on the 9lb pulley. 13.7 on the 11 so he thought it would blow. came to find out my cats were getting clogged. so now im just running 11psi but will be getting my methanol kit back up and running to go back to the track. I trapped 95 pre tires though lol so the tall tire may be hurting me.
Oh and really the whole thinking for me on a 28" tire was wanting more power a little down the line. I know 4th gear tops at about 124 with 3.73s and a 26" tire and I wish i would have stayed on stock gearing at this point because it was much nicer getting 3rd gear to go out to 100mph and 4th at 135. But yea I am sure that its not helping me.
BIGDATOWN
115
#14
  • May 17, 2011
  • #14
Go back to a 26" tire and you will both see a difference in accelleration. You really need a 4.10 gear to run a 28" tire. If it doesn't hook on 26's. Its time for suspension work.
04GTMustang
348
Stafford
May 17, 2011
#15
  • May 17, 2011
  • #15
yea i figured it was just my tires but always worries me because of how hard i push this car lol. it was trapping 95mph on nitto 315s on 11psi and was trapping 92 runnin 7.7s on 9psi on the kenne bell tune lol. So I knew that if I am running slower with a better tune and different tires than it had to of been something i just changed. IE the tires. But then again that was also the first time i had raced the car after the dyno tune. So maybe the tune isnt as good as the KB tune. Or its just far less aggressive lol who knows.
I also am just now getting around to installing my cold air kit from KB had the big tube kit on with stock airbox and my dyno tuner had my fan temps coming on at 200 degrees with the 160 thermostat so just this week i had him change them to 175 to come on. The blower was getting crazy heat soak sitting in the pit lanes.
superslothguy
103
#16
  • May 17, 2011
  • #16
i got it tuned the other day and its got 19 degrees of timeing and its at 11.7 across the board but well be giveing it a race tune this thursday with race gay see if we can add 4-5 degrees and see what she dose
as for as running a 26's i dont like em cause then i have to shift into 4th gear in the 1/8th
with my 28's i just top 3rd after i pass the finishline its perfect
04GTMustang
348
Stafford
May 18, 2011
#17
  • May 18, 2011
  • #17
hahahaha thats the same reason i wanted the 28s. 1/8th mile is what i normally run and i hated shifting to 4th just before crossing the line. it was either bang the limiter across teh line and lose time or shift to 4th and lose time. definitely was not fun.
and too if we continue to increase our power limits 4th gear is gonna be topped in a 1/4 as well. heck 11psi is gonna get you about 119 to 120mph in the 1/4 and 3.73s you will top at 124. so basically 14psi is gonna get you there. and 14psi safely is gonna be my future goal here.
I have already run 14psi with methanol but not at the race track. I just got the methanol up and running again last night so i may see whats up when the weather is nice and it stops raining.
BIGDATOWN
115
#18
  • May 18, 2011
  • #18
So just to clarify, you would rather run a 28 and be slower, than run a 26 and be faster because you have to shift into 4th? Something to think about. If anything just trn the rev limiter up 200 more per gear and it should take care of the last shift!
d98gt
4,505
59
204
SE Texas
May 18, 2011
#19
  • May 18, 2011
  • #19
superslothguy said:
i got it tuned the other day and its got 19 degrees of timeing and its at 11.7 across the board but well be giveing it a race tune this thursday with race gay see if we can add 4-5 degrees and see what she doseas for as running a 26's i dont like em cause then i have to shift into 4th gear in the 1/8th
haha
superslothguy
103
#20
  • May 18, 2011
  • #20
HAHAHA opps
1 of 2 Next Last
M
  • mnky99
  • Sep 5, 2025
mnky99
M
J
  • JRC99
  • Apr 19, 2025
JRC99
J
98 GT PI Swapped Engine Fires, Dies Immediately NOT PATS
  • MMccPerformance
  • Dec 2, 2023
  • SN95 4.6L Mustang Tech
2K
SN95 4.6L Mustang Tech Dec 20, 2023
Yel2002GTAuto
Y
Fresh Nitrous Tune
  • White Wolf
  • Jul 3, 2020
  • 2005 - 2014 Specific V6 Tech
2K
2005 - 2014 Specific V6 Tech Jul 4, 2020
White Wolf
A
Engine Turbo 5.0 Mustang bad misfire at WOT
  • AwxyMoron
  • Apr 3, 2021
  • 2 3
10K
Fox 5.0 Mustang Tech May 5, 2021
a91what
