I've had the alarm on this car since I bought it from the previous owner, I'm pretty sure it's an older alarm unit. When I go to school, I disconnect the negative battery cable so that the alarm doesn't drain the battery. When I come back, I always reconnect the battery, which sets off the alarm. I turn off the alarm with the key fob and I'm good to go. The last time I was home (Thanksgiving), the key fob stopped working so I just locked/unlocked the car with the key. I picked up a new battery for it today but it still does not work and I can't drive the car because I can't get the alarm to stop. I've tried connecting it and putting the key in the ignition or starting the car, but the alarm won't turn off. There is a switch mounted in the console next to a unit that controls the sensitivity of the alarm, and I switched that to the opposite position it was in thinking it would turn it off. This didn't work either. I'm at a loss as to how to get around this thing
bloopbloob
that sounds like a total pita!does it have starter kill? i'd just cut the wires to the horn, then ditch the whole thing. new alarms are much better, and only a couple hundred $$$ for a really good one.
with my old alarm, it started acting up on me, and i really wanted a 2way system, so i scrapped the old one. i love my 2way. i'm always paranoid about people f'ing with my car, and it gives me a lot more peace of mind. if the alarm ever goes off, my keychain vibrates, flashes, and beeps. my tire iron also sits right beside my apartment door . i think it has almost 1km reception also, which is very nice. you can be inside a mall, or in underground parking etc, and it will still alert you if your alarm goes off.
I don't think it has a starter kill, because the car started just fine, but the alarm was still going off
I thought about disconnected the alarm horn, but the LED in the interior is blinking like crazy and the locks go nuts from the alarm. I thought starting the car would disable the alarm but I guess that only works with the PATS system?
bloopbloob
Do you have a valet switch? If so, use it to shut the alarm off.
If the fob's battery was toast for long enough, the fob might need to be reprogramed, which is why it wont turn the alarm off.
Good luck.
Good luck.
I'm pretty sure that's the switch I found in the center console. I flipped it, but the alarm still goes off when I reconnect the batteryDo you have a valet switch? If so, use it to shut the alarm off.
Good luck.
Check the instructions for how to use the valet override. To shut if off, after the alarm starts to scream, you generally put the key to the 'run' position and flip the switch.
I don't have the instructions - the alarm came with the car. But I think I saw a mention of how to manipulate the switch when I was looking for info online. I think you have to flip the switch on and off, then start the car within 10 seconds. I'll give it a shot tomorrow.
Couple things.
A. you can download the directions
B. new keypads are available from viper dealers, and they will program it for you.
C. If i'm not mistaken, any viper product has a lifetime warranty. That's why they are the same (literally) as most Valet products, but the valet stuff is cheaper.
D. If it doesn't have a starter kill, it won't prevent anything.
Couple things.
I looked on Viper's site for a manual, but the fob doesn't have a model number or anything on it. Just "DEI" on the back and their website directs me back to Viper's. IF the valet switch doesn't work I will give them a call. As far as the starter kill, the alarm was on the car when I bought it - I'm just trying to troubleshoot.
Thanks for the replies.
I disconnected the alarm horn wire (which was just twisted and electrical taped ) and connected the battery. Turning the key to the on and then off position and then flipping the switch might have worked? I pressed the button on the remote and the LED lit up. The doors lock/unlock with the remote now so everything seems to be working. Maybe there's steps to reset the remote after you install a battery I didn't know about... I'm off to Walmart to get some wire connectors to fix the horn connection and then after Christmas maybe I'll get this sucker replaced..
- Replies
- 7
- Views
- 405
- Replies
- 4
- Views
- 252
- Replies
- 3
- Views
- 314
- Replies
- 1
- Views
- 318
