Voltage drop at Idle?!?
281CI96Coupe
233
Ok, I need some help figuring out whats going on with these small voltage drops. Here's the deal when the car is in drive and warmed up, when you come to a complete stop, the voltage drops a few in the word "Normal" on the dash. It usually right near the M but it drops to the "O/R" when you come to a stop. When driving you see the needle go up almost instantly to the M. Doesnt make sense, tensioner pully is going?
I know its not the alternator because when you drive its back to normal settings, and I know its not the battery because, it starts up all the time with no problems. Just lately its been acting like this. Anyone can point me in the right direction?
-Nate
-Nate
That gauge is a POS...I wouldn't worry about it
Use a meter on the battery. Have someone rev the engine up and then let it fall to idle and see what you get for voltage. Do it with the accessories on as well
I beleive above 1500RPM or so you should get 13.8-14.5 volts
At idle, anything over 12.0 would still be charging the battery
