Electrical Voltage on GEM high power fuse terminals with fuse removed.
LWood
Georgia USA
I have performed a dark test it shows less than 1/2 AMPS
the terminals for the high voltage fuse has 12.78 volts across them, with no fuse installed. this would mean I am picking up a negative some where. took fuses out one at a time, no change.took out the GEM, still voltage on terminals, with no fuse.to be clear it is across the place where the fuse goes.
I checked and removed the inertia switch from the trunk.
still the voltage remains. I removed the red wire from the battery to the bottom of the high voltage fuse box, I still have 7/10s of a volt.
I am left to believe there is a short on the high power fuse box for the fuse on the GEM
any Ideas?
