Air to Water is much better then Air to Air, and $1500 is cheap for what you get. Air to water is only good if you change the water/ice. A air to air set-up is better for the daily driven street car. I think Vortech has a kit, I know Paxton does and they are all the same company now. I'd call and ask.......
I don't think it is a good idea for you with your A-trim since you will lose atleast 3 pounds of boost. The slight gain you'll see there since your spinning the blower higher will be minimal with the rise in air temp. If you had an S-trim, I's say go for it if you like the unit. Once you start changing pullies and spinning a A-trim higher then create an extreme amount of heat.
An air to air will run you around $600-$1000 for a good unit, then you will need to fab all your pipes, get a blowthrough MAF, blow off valve etc...
