vortech boost problem
  • Thread starter Thread starter rafelos1337
  • Start date Start date Jul 3, 2005
rafelos1337
20
Clovis, NM
Jul 3, 2005
  • Jul 3, 2005
Well i have a vortech and when i first put it on i was getting 10 lbs. of boost now im only getting 7 or 8. I tried to to tighten it more but i didnt get it much tighter. I this the cause of my lost boost or could it be something else?
is there like a cog belt or whatever that i could get that would eliminate that problem if it is a big issue with belt slippage. thank happy 4.
D
Daggar
3,902
  • Jul 3, 2005
Have you disconnected the vac line from your bypass valve to ensure that it's fully closing?
shewitt
85
Newnan GA
Jul 3, 2005
  • Jul 3, 2005
look to make sure your not loosing it from a leak on a gauge or thru some other vac line. and dont tighten the belt to tight you could mess up the s/c.
Ranchero5.0
The Voice of Reason
Jan 1, 1999
5,306
Hagerstown MD
Jul 3, 2005
  • Jul 3, 2005
Also realise you lose a lot of boost with heat. Winter gives me almost 9psi and summer gives me 5-6psi...
Belt tension typicly just hurts the belt or bearings.
Jamie
D
Daggar
3,902
  • Jul 3, 2005
Good point
shewitt
85
Newnan GA
Jul 3, 2005
  • Jul 3, 2005
ya but it seems like he is talking about one day to another not seasons. And like i said dont make it to tight you should we able to twist the belt about half way around. What was going on on mine was that i would get 8 for about half a day then it would get lower to about 4 i found it was a vac line going to the spliter on the fire wall was coming off went over all lines found some small leaks no problems anymore. But at first i thought my belt was loose made it so tight i could hear the s/c kind of grinding like i said you will screw it up if its to tight.
Forced Induction Total Timing under boost
  • Dontknowchit
  • Aug 27, 2025
Fox 5.0 Mustang Tech Aug 28, 2025
Dontknowchit
C
Vortech water pump and tensioner pulley issue
  • Crooner88
  • Feb 26, 2025
2K
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Mar 13, 2025
revhead347
L
95 gt engine vibration
  • lenzgt
  • May 11, 2026
  • 1994 - 1995 Specific Tech
1994 - 1995 Specific Tech May 26, 2026
lenzgt
L
M
Engine Unexplainable Exhaust Pop and Gurgle
  • Mrnissen122
  • Feb 14, 2026
Fox 5.0 Mustang Tech Feb 18, 2026
Hello Everyone !
  • 5150K
  • Jul 3, 2026
  • The Welcome Wagon
The Welcome Wagon Jul 3, 2026
5150K
