  • SN95 4.6L Mustang Tech
Vortech driveability
  • Thread starter Thread starter bobc83
  • Start date Start date May 22, 2009
1 of 2 Next Last
bobc83
130
Normal,IL
May 22, 2009
  • May 22, 2009
Hey guys
Got a 03 gt here with a newly installed vortech s-trim and I am having some driveability issues. At WOT and the track....the car is perfect, a little puff of smoke on this shifts, but hey I can deal.
When driving around town like a good little mustang, I get some bucking when lets say, I'm in third gear, 3k rpms, and other times too. I've been driving my friends procharged mach all week and it drives just as smooth as can be.
I'm also see some stalling when coming to stops. The idle will jump around a couple hundred rpms and then sometimes just die at a stop light.
Had a very reputable tuner do my tuning and I have pretty much done everything suggested to me: replace plugs, check for air leaks (which I can't any find by myself), adjusted the bypass valve correctly. A couple people have told me that my MAF is getting some "wash" or turbulance.
The sequence goes: air filter, SCT2400 maf, powerpipe then head unit.
If anyone has any kind of insight as to what I should take as my next step to solving the issue, please let me know, I would be very greatful. Or perhaps more info is needed from me on my setup or about the car's behavior. I understand I have modded the gt, but it seems like it should be alot more well behaved, it's not 600hp or anything.
bobc83
130
Normal,IL
May 22, 2009
  • May 22, 2009
draw-thru setup I should add.
spederman
732
  • May 22, 2009
sounds like the tuner tuned it perfect for WOT only. A lot of tuners do that and call it good and dont spend enuf time on the daily drivability of the tune. At least thats what i have dealt with in my experience. And ive also been to very "reputable tuners". Thats why i'm now driving 500 miles to get tuned perfectly by somebody that really knows their stuff.
BlownStangGT
REPEAT
3,860
Lancaster, PA
May 22, 2009
  • May 22, 2009
Yeah that sounds wierd. Even with my car, its has an OLD tune on it where the timing is locked. SO its running low timing at idle and low cruise speeds compared to a tune that takes in account for when you are not WOT. So mine is pretty much tuned for WOT, but like I said, its an old school autologic chip that didnt have the technology they have now. But I cant say mine does that at all even with the wierd tune. Best bet would be to let them look it over I guess. Couldnt be something small you are missing. But I have no problems with my vortech at all
2000GTdriver
47
Mile High City, Colorado
May 22, 2009
  • May 22, 2009
Did you change your fuel pump? How are you adding fuel under boost?
DBMSTNG
I fantasize about it being BIG!
2,120
not quite here
May 23, 2009
  • May 23, 2009
i have to agree with the people who think it's backflow. what bypass do you have? if it's the cheap plastic one Vortech gives you, it may need changed. make sure all the vacuum lines are connected.
AdRock
521
South Texas
May 24, 2009
  • May 24, 2009
I agree with this. I've seen too many people get an awsome tune only to find out the tuner didn't do much if anything for everyday driveability. If I was you I'd take it to a different reputable tuner and see if they can fix the tune issues becuase it sounds as if the guy now doesn't want to mess with it. He's just having you throw parts at it instead of really getting deep into the tune.
bobc83
130
Normal,IL
May 25, 2009
  • May 25, 2009
Fuel Pump is a single GT supercar pump.
I have the mini race valve.
Talked to tuner and daily driving was definitely accounted for. Aparently after a second look, my bypass valve is causing alot of MAF wash, so I am going to try a stock bosch, picked one up for real cheap. He tells me that its not that the mini race is moving too much air, its that its moving too much air at idle/part throttle and blowing into the inlet pipe and causing turbulence.
Bob Kurgan is awesome and I'm positive he tuned it for daily driving conditions as well. If this doesn't clear my problems up, he is going to take another look at it.
lol I think I need to make a progress thread, I have many more goodies I have purchased
R
rconaway
1,415
Phoenix, Az.
May 26, 2009
  • May 26, 2009
When I got my S-Trim from Steeda, the driveability was like stock. If you don't have a lot of mods other than the S-Trim, I would contact them.
SVT32VDOHC
waiting for the next hack atta
3,501
28
119
Motor City
May 26, 2009
#10
  • May 26, 2009
  • #10
I had a Procharged Mustang GT that had the bucking problems really bad. I had it tuned and all was well afterwards.
BlownStangGT
REPEAT
3,860
Lancaster, PA
May 26, 2009
#11
  • May 26, 2009
  • #11
Well start one LOL....I wanna seee!!!!!
T
TonyG
200
Owings Mills, MD
May 26, 2009
#12
  • May 26, 2009
  • #12
Jimmy Larocca, right? I used to have an autologic/locked timing tune from him. Driveability wasn't that great, but the car ran awesome at the track with the locked timing.
96SCstang
228
novi, MI
May 27, 2009
#13
  • May 27, 2009
  • #13
you are exactly right....the stock bosch valve works great for anything under 14 lbs. i had the EXACT same problem with my car and i had the mini race too. my tuner(which was Lidio from Alternative Auto) said the same thing. it moves too much air. anytime i would cruise at 3 grand or above my car would surge and you could actually hear the mini race rapidly blowing off. i put the stock bosch valve on and all gone. put it on and you will be all better. the mini race is ONLY needed for high horsepower/ high boost applications and actually causes more problems when used on our kind of setups.
bobc83
130
Normal,IL
May 27, 2009
#14
  • May 27, 2009
  • #14
ahh, gracias senior for your input. I have purchase a bosch valve and will update just as soon as I figure out how to tap into this giant hole where my mini race was lol.
How did you do it? or mind sending me a pic
96SCstang
228
novi, MI
May 27, 2009
#15
  • May 27, 2009
  • #15
lol....i had some spare pipe from my fmic so i just had my boss tig weld a one inch pipe on it and put in place of my bov pipe. you might have a different setup but mine was pretty easy actually. i had the mini race on top of the pipe before because it was so pretty but the bosch one is tucked in under the pipe lol
spederman
732
#16
  • May 27, 2009
  • #16
ive got the mini race on my setup, but i have a blow thru setup, so the mini race works perfect for my application. I started off with the bosch bov and it was giving me a lot of probs with drivability so i switched to the mini race and all is well. It must make a big difference on if u are draw thru vs blow thru.
BlownStangGT
REPEAT
3,860
Lancaster, PA
May 28, 2009
#17
  • May 28, 2009
  • #17
Yup it came from him haha. Well now that I think about it, the only thing I really notice at driving is if I cruise at like 2500 in like 3rd or somnething for like 1/8th mile or something it will act a little wierd....but other then that its pretty good, but then agian, when I drive it only a handful of times in a month I guess I cant tell all the time haha. But thats already, Ill let Dave at SGS get a new x-cal tune on it along with a smaller pulley this fall
bobc83
130
Normal,IL
Jun 16, 2009
#18
  • Jun 16, 2009
  • #18
UPDATE
made some bypass valve and powerpipe mods and the car drives 100x better. Not even the same car. Made some adjustments to the idle's in the tune as well and it's muuuuch better.
BlownStangGT
REPEAT
3,860
Lancaster, PA
Jun 17, 2009
#19
  • Jun 17, 2009
  • #19
good to hear
96SCstang
228
novi, MI
Jun 17, 2009
#20
  • Jun 17, 2009
  • #20
that's great....glad it fixed it
1 of 2 Next Last
Ford truck engine swap issues
  • keel
  • Jul 7, 2026
  • Other Auto Tech
Other Auto Tech Jul 13, 2026
General karthief
idles perfect then jolts and cuts out when put into Reverse or Drive.
  • shanesstangs
  • Mar 12, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Apr 27, 2026
General karthief
F
2004 Mustang GT – Fuel Pump Not Priming
  • Fayio
  • Apr 22, 2026
SN95 4.6L Mustang Tech Apr 27, 2026
n0v8or
N
P
Weird Voltage & Oil Pressure Gauges
  • PNN
  • May 22, 2026
  • SN95 V6 Mustang Tech
SN95 V6 Mustang Tech May 22, 2026
PNN
P
L
1997 V6 Starting issue
  • leanzik04
  • Mar 20, 2026
SN95 V6 Mustang Tech Mar 20, 2026
