Alright so not too long ago I installed a used Vortech V2 supercharger on my 2004 GT. The kit was used but was in good condition and I replaced many things where necessary and so far it has been good. However, while installing the supercharger tapping the oil pan was a huge pain in the ass. I did exactly as the instructions said and used a punch rather than a drill than carefully tapped the hole. Well despite my precautions it still didn't turn out quite perfect and eventually some JB weld was necessary. Well recently I had to replace the oil feed line (leaky fitting) and than just today replaced the return line. But when I was trying to carefully slide the new hose onto the L shaped tube coming from the oil pan I noticed a tiny bit of oil seeping from the connection between the oil return line fitting and the pan.
Basically I am going to need to get a new pan and weld a bung in (do it the right way as it should have been originally) and attach it securely that way. My question is does anyone know where I can find a cheap oil pan for an 04 GT or does any company make such a pan with the bung already welded in? That would save me some time.
