Vortech S/C tech questions
deftsound
Please ask me how much my supercharger cost
Apr 6, 2004
945
Texas City TX
Well I just got my s/c put on yesterday (not tuned yet), and I was reading up on it and it said I needed to change the oil in the s/c every 6k miles.
My question is are there any other important things i need to remember to be doing as far as maintenence is concerned. Im switching to royal purple synthetic oil from here on out. What else should i do to help ensure the longevity of my motor and s/c?
don't run too much boost for the stock internals and i would get a valve cover breather (if you don't have one) so your dipstick doesn't shoot out and send oil flying everywhere! keep a closer eye on your oil level than normally and change it very regularly as well.
check your spark plugs a lot more often... maybe once a month.
LOl..If its tuned correctly there is no need for checking plugs once a month.
Besides changing the oil its no different than the service you do on it n/a.Except plugs(copper require changing a little more often 15k or so miles for best performance all the time).And MAYBE a drive belt (if you have excessive slip) But i usually changed mine once a year anyways.
BTW-dont get on it till its TUNED or you will need more than just regular maintance.
I have heard nothing but good things about royal purple, but god damn spending 40$ on an oil change sure is a bitch, i used 10w-30
I've heard of busted lifters and rod knock. Not only that, Mobil 1 oil can withstand more heat and friction. It also has more cleaning detergents compared to other brands. Look at some tests on google, they are interesting.
Plus, Mobile 1 is $20 for 5 quarts at Walmart:nice:
I will definately remember that, 20$ sure beats the 6.99/qt i shelled out for royal purple
Vortech recommends synthetic oils only, so I'm going to trust the designer on that one. I would rather trust a huge company like that, than a tuner.
is there any reason to use 5w-30 instead of a heavier weight like 10w-30 when in a blown application? I used 10w-30 because its summer and its hot as hell down here in south texas...
Honestly, I think our cars are made for thinner oil because the oil passages in the engine are small. I think you would be better off with with 5w30 oil.
