  • SN95 4.6L Mustang Tech
Vortech SQ Question
  • Thread starter Thread starter mustangGT2001
  • Start date Start date Jun 10, 2006
mustangGT2001
30
Miami
Jun 10, 2006
  • Jun 10, 2006
hello all just a question i just installed a vortech SQ blower on my 2001 GT, the GT put out 270 with all my modes, mid tube headers, dragon plenum and 75mm dragon throttle body, 3.73 gears, steeda cat back system with off road X pipe, with the blower installed i got 376.4 HP and 362.05 Torque just installed a boost gauge and at idel pulling 30 inch of vacuum and when i punch it it boost at about 6 PSI or so is that possable with the stock 3'60 pully or am i doing the test all wrong, the car pulls awesome should the HP be higher with that pully? or is that about right BTW i also have the steeda boost pipe installed any input would help thanks.
Luis
01Steeda
732
Baton Rouge, LA
Jun 10, 2006
  • Jun 10, 2006
all of that sounds pretty much dead on
Dope 97GT
439
Rochester, NY (SUNY Brockport)
Jun 10, 2006
  • Jun 10, 2006
that sounds like the power that that kit is puttin out. Those numbers are almost identical to about 2-3 others on this forum with the same vortech setup.
I say its good numbers for only 6psi
mustangGT2001
30
Miami
Jun 10, 2006
  • Jun 10, 2006
now to get more HP i can change the pully and boost more correct and if soo what HP i may see
bryan0
175
Bethel, CT
Jun 10, 2006
  • Jun 10, 2006
you can get a boost pipe (powerpipe) to replace the inlet tube. They run like $200 and are supposed to give you another 1-2psi. You can obviously swap out the pulley too, but don't get to crazy as the stock gt blocks are only good to around 400rwhp.
BennyBlown2v
1,233
Carmel, INdiana
Jun 10, 2006
  • Jun 10, 2006
He already has a Steeda boost pipe.
Numbers sound good, great for 6psi - headers and exhaust are probably helping you alot. Peak boost should be between 6-8psi with 3.6" pulley and Steeda boost pipe (it's not as efficient as MPH or AFM boost pipes as its about 1" smaller in diameter, I saw 9psi with 3.6" pulley and MPH 4" boost pipe, now I see 11.5psi with 3.3" pulley).
Yes, you can change the pulley to gain more power - but you have to make sure your tune is safe or else you may end up popping the motor. Adding an intercooler will allow you to "safely" run more boost and more timing to make MORE power, also.
P
Pennywise2
Banned
May 16, 2006
1,379
  • Jun 10, 2006
Yep those numbers sound about right.You should try changing the pulley size.
laxdman20
95
Va.
Jun 11, 2006
  • Jun 11, 2006
30 In of vacuum, is that right? Mine only does 17 in. Hg. at idle. And I hit 9 1/2-10 lbs of boost with my setup. 413/413 hp/tq.
C
Boosted Boss 302 HP/TQ
  • coltoncaskey12
  • May 24, 2026
  • 2010 - 2014 Specific Tech
2010 - 2014 Specific Tech May 24, 2026
coltoncaskey12
C
Subframe connector question
  • B0udreaux
  • Jan 27, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Feb 5, 2026
rednotch
A
Blow through intercooled questions
  • AngryH58
  • Aug 31, 2026
1996 - 2004 SN95 Mustang -General/Talk- Sep 1, 2026
AngryH58
A
Fuel Vortech Supercharger injectors
  • Dontknowchit
  • Mar 13, 2025
Fox 5.0 Mustang Tech Mar 8, 2026
from6to8
Forced Induction Bypass valve backwards?
  • Dontknowchit
  • Jun 25, 2025
Fox 5.0 Mustang Tech Jun 29, 2025
JD1964
