vortech t-rex
  • Thread starter Thread starter 90bluecoupe
  • Start date Start date May 8, 2011
9
90bluecoupe
76
Abingdon md
May 8, 2011
  • May 8, 2011
Im putting in a t rex fuel pump and it says in the trunk to tap the red/purple wire or on some cars its a brownish green wire for the pump. Well i have a fat red wire with a black spripe 2 fat black wires and a smaller yellowish green not brownish at all. Can anyone help with this?
2000xp8
SN Certified Technician
Aug 8, 2003
8,071
1,655
194
NJ
May 8, 2011
  • May 8, 2011
While i can't help with the t rex, i can save you some future issues.
Skip the trex and just use an in tank gss340 high pressure walbro pump.
All the trex pump does is complicate a very simple situation.
281pony
2,681
Oly, WA
May 8, 2011
  • May 8, 2011
i am running out of fuel using a non-walbro 255 lph pump.
do these pumps support 450+ rwhp with a single application? i am looking at the t-rex as well for helping to cure my lean issue past 5300 rpm's. you think they flow enough fuel to void out the need for a secondary pump?
2000xp8
Aug 8, 2003
8,071
1,655
194
NJ
May 9, 2011
  • May 9, 2011
You have to be using the gss340 HP version, should support over 500rwhp, on one car i seen it supporting 513rwhp.
There is also a non high pressure unit, which is probably what you have. BTW, most pumps regardless of the name on it, are made by walbro.
281pony
2,681
Oly, WA
May 9, 2011
  • May 9, 2011
i have one sold by high flow fuel systems or whatever. they have a chart that shows flow comparisons of a walbro gss340 and their pump. they show it outflowing the walbro..
regardless, i ordered a walbro to try and fix my issue. hope it works..
Electrical 91 hatch wiring help needed
  • FastDriver
  • Apr 7, 2026
Fox 5.0 Mustang Tech Apr 8, 2026
FastDriver
G
Resolved Smoking Wiring Issue After GT40 Head Swap
  • Grapes
  • Aug 15, 2026
Fox 5.0 Mustang Tech Aug 22, 2026
Grapes
G
1999 Mustang GT - No Start- Need help understanding the fuel pump circuit and how it works
  • 99gtGuy
  • Nov 4, 2025
1996 - 2004 SN95 Mustang -General/Talk- Nov 7, 2025
04newedge-
  • dan50
  • Jul 18, 2026
dan50
Fox Fuel Pump Issues After Replacement/Upgrade
  • Ryu
  • Jun 23, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Sep 13, 2026
Ryu
