I’m in need of a little bit of part number assistance. I’m piecing together a Vortech V1 S trim kit for a 2002 Mustang GT and am in the final stages. I went on Vortech to find an idler pulley (4FL116-150) and to my shock it was around $80 dollars. Has anyone out there used a cheaper alternative and/or have the part number from it. I have done some research and it seems that some Mercedes used a 6 rib idler pulley that is 65.4mm, the Vortech idler uses a 66.04mm (2.6 inch) pulley, would this work in the setup or would there be too much slack in the belt. Any help or input would be appreciated, thank you.
