  • SN95 4.6L Mustang Tech
Vortech V2 HELP
  • Thread starter Thread starter BanginStang97GT
  • Start date Start date Nov 8, 2004
BanginStang97GT
1,025
Jersey
Nov 8, 2004
  • Nov 8, 2004
I'm running a v2 s-trim and I would like to add a blow-off valve. Call it rice or not I like the sound. Back on topic, could I run my MAF that is infront of the blower behind the blower without mechanical problems? I mean my real question is infact I guess is that what differentiates a blow-thru maf from a stock MAF (draw-thru)? The only difference I can see is its location. Thanks. Oh yah 1 more ques. who makes a loud BOV?
BanginStang97GT
1,025
Jersey
Nov 8, 2004
  • Nov 8, 2004
Someone has to know something about this.
BanginStang97GT
1,025
Jersey
Nov 8, 2004
  • Nov 8, 2004
Just give me 1 person to confirm my aligations before I start cutting up the draw trough maf.
M
mrpositraction
296
Columbia, MO
Nov 8, 2004
  • Nov 8, 2004
I don't know a lot about BOV but I was under the imperssion they were bad for the supercharger (at least twin screw) because of the sudden jolt it puts on the system, I may be wrong, but that is what I thought I have read. Not my cup of tea but more power to you man, whatever spins your beanie
340.29m/s
213
Blue Springs, Mo
Nov 8, 2004
  • Nov 8, 2004
You can not just take a flow thru maf and put it after the blower. You need a blow thru maf and then you will be set to use a BOV.
A BOV does NOT add a sudden jolt - a BOV (and bypass valve) is in place to STOP the jolt (boost that has no place to go) from happening.
Personally, I would stick with the bypass valve, but do whatever floats yoru boat.
Here is some good info on BOV/Bypass http://twinturbo.net/ttnetfaq/FAQpages/bov.html
DBMSTNG
I fantasize about it being BIG!
2,120
not quite here
Nov 8, 2004
  • Nov 8, 2004
i think someone used the 90mm LMAF with a BOV with mild sucess. i wouldn't advise it tho.
BanginStang97GT
1,025
Jersey
Nov 8, 2004
  • Nov 8, 2004
Ok, do you guys know what the difference between the blow thru and the draw thru is? I will buy a blow thur to make this work so I dont hurt anything. It's just bothering me because the structure of the two is very similar. Do they give out different readings or meter a different way from each other?
BanginStang97GT
1,025
Jersey
Nov 8, 2004
  • Nov 8, 2004
Also am I running enough boost to run a vortech race bypass? I just want something to make noise under the hood. The v2 isn't very talkative over like 1500 rpms lol.
BanginStang97GT
1,025
Jersey
Nov 9, 2004
  • Nov 9, 2004
Thanks to those that posted. Not as much info as I would have hoped but enough to shy me away from doing it. Thanks again.
A
Blow through intercooled questions
  • AngryH58
  • Aug 31, 2026
1996 - 2004 SN95 Mustang -General/Talk- Sep 1, 2026
AngryH58
A
Vortech V3 Si - Bypass Valve to BOV swap issues
  • seanmahoney
  • Jun 26, 2025
SN95 4.6L Mustang Tech Jun 26, 2025
seanmahoney
T
First Car, what should I do for power??
  • tunedV6
  • Apr 13, 2026
1996 - 2004 SN95 Mustang -General/Talk- May 4, 2026
580HP*428Cj
F
Ford 460 swap
  • Ford460
  • Sep 13, 2026
Ford460
F
J
PCV system help for S/C
  • jay99914
  • Feb 16, 2025
SN95 4.6L Mustang Tech Sep 26, 2026
AngryH58
A
