VSS help!!!
Abbadon
did mass air conversion, added new vss and plug from napa. wires in new plug are both white, does it matter which wire goes to which pin? i would assume so.
Thanks
I am 90% sure it doesn't matter and will function either way.
Depending on the year, a vss plug may already be hanging nearby, in which case you just need to tap into the wiring in the drivers side kick panel.
