Vss
  • Thread starter Thread starter mustangGT85
  • Start date Start date Dec 8, 2005
mustangGT85
264
Orange CA
Dec 8, 2005
  • Dec 8, 2005
Do i need my VSS hooked up for my engine to run perfect. what i mean is, if i disconnect it, will the ECC run out of whack? and make the engine run worse?
~Steve
ss93cobra
1,422
Wilmington NC
Dec 8, 2005
  • Dec 8, 2005
If your car is mass air, you'll have stalling concerns. Not sure about whether or not it'll happen if its speed density though...
mustangGT85
264
Orange CA
Dec 8, 2005
  • Dec 8, 2005
intresting
HISSIN50
34
129
Dec 8, 2005
  • Dec 8, 2005
The engine should run fine. YOu might have to bump the idle a hair.
FWIW, I cant remember but I dont think Yount has his VSS hooked up on his conversion (I could be wrong).
Good luck.
T
TheUser
1,859
Springfield, MO
Dec 8, 2005
  • Dec 8, 2005
you mean an absent VSS won't effect how the IAB/IAC works and cause issues when hitting the clutch while the car is rolling?
HISSIN50
34
129
Dec 8, 2005
  • Dec 8, 2005
James, if directed at me, that not really what I mean. The lack of the VSS connection will affect the rolling idle, so one might have to bump the idle setting a little to compensate (ergo use a higher static hot idle). Some guys dont like the rolling idle hang and tune it out altogether. I like it, but dont have issues [that some do with it].
srothfuss
Last night I stabbed the same guy 7 times in a row
Oct 17, 2004
1,796
Woodward Ave.
Dec 8, 2005
  • Dec 8, 2005
If the VSS isn't connected, the computer will think that the car is going "0" MPH correct? So basically when you are rolling and press the clutch, the RPM's will drop below 1000. I don't know if that will cause any stalling issues... might even save a little gas by not reving higher when you creep to a stop.
Michael Yount
Mustang Master
Apr 10, 2002
9,039
Charlotte, NC
Dec 8, 2005
  • Dec 8, 2005
The ecu's use VSS for different things in the cars. For example, in the SN95 cars, the ecu turns off the electric cooling fan when the speed exceeds 25mph. VSS signal is used to limit top speed in cars that have that feature. In the fox bodies, one thing the VSS signal is used for is to hold the idle speed a bit higher when you're decelerating. If you have a manual tranny, slip it into neutral and watch the tach. It'll hold it around 900-1000 rpm until you roll to a stop - then it will drop down.
My car has never had a VSS hooked up -- 10 years, 43k miles. Doesn't seem to have posed a problem.
mustangGT85
264
Orange CA
Dec 9, 2005
  • Dec 9, 2005
so if i convert my 87 AOD to MAF, do you think i might start encounter these stalling problems?
~Steve
Electrical Code 29 again
  • Creomod
  • Jul 31, 2026
Fox 5.0 Mustang Tech Aug 3, 2026
Creomod
T
Electrical Brown Connector #31
  • ta66
  • Jul 26, 2026
Fox 5.0 Mustang Tech Jul 30, 2026
ta66
T
Removing speedo cable from the VSS
  • 91AOD5.0LX
  • Mar 25, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Apr 25, 2026
91AOD5.0LX
Electrical Starter solenoid green wire?
  • 387lx
  • Jun 1, 2026
Fox 5.0 Mustang Tech Jun 2, 2026
AeroCoupe
K
Engine Gt40p vs 180 procomp
  • Kleinjj27
  • Oct 27, 2026
Fox 5.0 Mustang Tech Nov 3, 2026
Kleinjj27
K
