  • SN95 4.6L Mustang Tech
Vt stage 2 cams
  • Thread starter Thread starter TNstanggurl
  • Start date Start date Oct 7, 2004
T
TNstanggurl
153
TN
Oct 7, 2004
  • Oct 7, 2004
Just wondering if we will have ptv contact if we get the VT stage 2 cams. We have the comp 270's right now and have pretty much came to the conclusion that we are have ptv at high rpm's. I called comp and they said that the lifters are pumping up and that is what is causing it. So I just wanted to make sure that if we get the stage 2 we will not have ptv contact.
G
GinoGT
1,862
Oct 7, 2004
  • Oct 7, 2004
I haven't heard of any PTV issues for VT's cams. Stupid SHM puts that 5* advance into their cams.
T
TNstanggurl
153
TN
Oct 7, 2004
  • Oct 7, 2004
vt's
ttt
J
jbrown
393
Tallahassee, FL
Oct 7, 2004
  • Oct 7, 2004
heres a stupid question what is PTV?
G
GinoGT
1,862
Oct 7, 2004
  • Oct 7, 2004
Piston to Valve contact, usually caused by the cams not being timed right, or having too much lift.
Yes, it is as bad as it sounds. Very effective way of trashing engine components.
maddogg545
91
NJ
Oct 7, 2004
  • Oct 7, 2004
When you engine has PTV does it make a wierd sound? If so, what does it sound like?
Y
YellowJacketGT
108
  • Oct 7, 2004
VT stage 2 port with Comp 268 cams CP 17cc pistons..
Had to fly cut for valve clearance..
Great sound.... Not too aggresive
kboy262
437
Atlanta-Kennesaw
Oct 8, 2004
  • Oct 8, 2004
I to second the 268H. Grant it they are on my NPI head car, they are great mod. Not too aggressive but helps out a lot in the higher end of the powerband. No problems so far after 6,000 miles.
Avenger
1,030
QC
Oct 8, 2004
  • Oct 8, 2004
Dyno results
I know it hasn't been asked but I think this is the right thread to present some dyno numbers
VT Stage 2 cams on stock 00 GT
nickthegenius
1,631
Elwood, IN
Oct 8, 2004
#10
  • Oct 8, 2004
  • #10
In the worst cases, it sounds like the clicking of your injectors x 100 and can hear it over your exhaust and everything. Less severe cases you may just hear a light metallic clicking/tapping at higher RPMs. Either way, it is bad for the engine and can trash you pistons, valves, and possibly the head depending on how the piston hits the valve and what it pushes it into.
P
prsrizdgt
231
St. Louis
Oct 8, 2004
#11
  • Oct 8, 2004
  • #11
I am a little coonfused now. The forged piston is dished 17cc's right? And the comp cam only has .550 lift. Why cut the pistons for valve relief?
kboy262
437
Atlanta-Kennesaw
Oct 8, 2004
#12
  • Oct 8, 2004
  • #12
Actually I think he says his are the 268H (NPI cams) not 268AH. The 268H have only .500" lift.
Y
YellowJacketGT
108
#13
  • Oct 8, 2004
  • #13
These are ported heads. They were milled a bit to clean them.
The reason they need to be cut is they were hitting the edge. The shop did an on engine manual test. The disk is in the middle of the piston. The outer edges are still high...
Actually I made a mistake the Comp cams are XE270AH. .550 lift Duration @.050 Intake 234 Exhaust 238..
These cams significantly opened up my top end. HP stays flat up top rather than fall off.. 5500 - 6400 stayed at 500rwh..
nickthegenius
1,631
Elwood, IN
Oct 8, 2004
#14
  • Oct 8, 2004
  • #14
Don't forget that the lift isn't the only thing that can cause PTV. Another thing with the Comps is the extra 5* advance that is ground into them. Add that to a cam that already has a decent amount of duration and you end up with the valves open long enough that the piston meets it at the top of the bore and *bam*.
P
prsrizdgt
231
St. Louis
Oct 9, 2004
#15
  • Oct 9, 2004
  • #15
YellowJacket, did you go with forged rods also? What brand of parts did you choose?
T
Drivetrain TREMEC TKX 1–2 Grinding Issue at ~4,000 Miles + Poor Warranty/Customer Service Experience
  • Ttopfoxguy
  • Oct 10, 2026
Fox 5.0 Mustang Tech Oct 15, 2026
JMG9350
J
Surging/stalling! problem or tune?
  • djj62478
  • Oct 4, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Oct 14, 2026
KRUISR
Engine 2003 Mach 1 Automatic Upgrades assistance
  • SJK1417M1AT
  • Sep 25, 2025
SN95 4.6L Mustang Tech Dec 21, 2025
01SVTvertt
K
Procharger Stage 2 - 2013 Mustang GT Minor Hiccups
  • KHills5058
  • Oct 9, 2025
  • 2010 - 2014 Specific Tech
2010 - 2014 Specific Tech Oct 9, 2025
KHills5058
K
K
2013 Mustang GT Procharger Stage 2 Kit Issues
  • KHills5058
  • Oct 9, 2025
2005 - 2014 S-197 Mustang -General/Talk- Oct 10, 2025
KHills5058
K
